Up to 20% off select tools
Sony Alpha NEX-5N Camera Image Sensor Replacement
Views: 7.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
32
Past 30 Days:
171
All Time:
7,435
Comments: 6
6 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
To replace the camera image sensor, the majority of the device will need to be taken apart. Organization will be crucial in order to reconstruct the device, and make the camera work properly. This repair may be needed if your device is capturing photographs that appear completely black, or contains random patches of light.
    1. Sony Alpha NEX-5N Camera Image Sensor Replacement, Motherboard: step 1, image 1 of 3 Sony Alpha NEX-5N Camera Image Sensor Replacement, Motherboard: step 1, image 2 of 3 Sony Alpha NEX-5N Camera Image Sensor Replacement, Motherboard: step 1, image 3 of 3
      • Unscrew the 3 silver 1.2 mm Phillips #000 screws from the bottom of the camera.
      • This does not include the two screws in the bottom of the LCD screen panel.
      Ask FixBot
    2. Sony Alpha NEX-5N Camera Image Sensor Replacement: step 2, image 1 of 1
      • On the bottom casing, locate the split along the tripod port.
      • Insert the prying tool into the split.
      • Pull the prying tool towards the LCD screen to begin separating the split.
      • Jiggling the prying tool may be necessary to open the split.
      Ask FixBot
    3. Sony Alpha NEX-5N Camera Image Sensor Replacement: step 3, image 1 of 1
      • Hold the device with the lens facing you, and grasp the battery compartment.
      • Locate the split on the side of the battery compartment.
      • Locate the split and insert the prying tool.
      Ask FixBot
    4. Sony Alpha NEX-5N Camera Image Sensor Replacement: step 4, image 1 of 1
      • Locate the charging port.
      • Unscrew the silver 3.5 mm Phillips #0 screw next to the port.
      Ask FixBot
    5. Sony Alpha NEX-5N Camera Image Sensor Replacement: step 5, image 1 of 1
      • Open the battery compartment.
      • Unscrew the 2 silver 3.5 mm Phillips #0 screws found at the inside bottom of the battery port.
      Ask FixBot
    6. Sony Alpha NEX-5N Camera Image Sensor Replacement: step 6, image 1 of 1
      • Insert prying tool in the split between the top panel (where you find the movie button) and the LCD screen.
      • Jiggle the prying tool and pull the tool away from the device.
      • The panel will fall off immediately.
      Ask FixBot
    7. Sony Alpha NEX-5N Camera Image Sensor Replacement: step 7, image 1 of 2 Sony Alpha NEX-5N Camera Image Sensor Replacement: step 7, image 2 of 2
      • Unscrew the silver 3.5 mm Phillips #0 screw, visible on the left top edge when looking at the face of the device.
      • The dark gray panel that surrounds the shutter button and covers the battery compartment will be loose.
      Ask FixBot
    8. Sony Alpha NEX-5N Camera Image Sensor Replacement: step 8, image 1 of 1
      • Locate the middle top of the device.
      • Unscrew 2 copper 1.2 mm Phillips #000 screws.
      Ask FixBot
    9. Sony Alpha NEX-5N Camera Image Sensor Replacement: step 9, image 1 of 1
      • To the right of where you unscrewed the copper screws, unscrew 4 black 1.2 mm Phillips #000 screws.
      Ask FixBot
    10. Sony Alpha NEX-5N Camera Image Sensor Replacement: step 10, image 1 of 2 Sony Alpha NEX-5N Camera Image Sensor Replacement: step 10, image 2 of 2
      • Locate the tripod port.
      • Unscrew 2 black 1.2 mm Phillips #000 screws, one on each side of the tripod port.
      • Pull the section holding the LCD screen away from the device body.
      Ask FixBot
    11. Sony Alpha NEX-5N Camera Image Sensor Replacement: step 11, image 1 of 1
      • Unscrew 2 copper 1.2 mm Phillips #000 screws underneath the lanyard loop (near the control wheel).
      Ask FixBot
    12. Sony Alpha NEX-5N Camera Image Sensor Replacement: step 12, image 1 of 3 Sony Alpha NEX-5N Camera Image Sensor Replacement: step 12, image 2 of 3 Sony Alpha NEX-5N Camera Image Sensor Replacement: step 12, image 3 of 3
      • Pull off the metal back from the device body.
      • Locate a thin metal piece on top of the motherboard, and unscrew 4 silver 1.2 mm Phillips #000 screws in the corners of the metal piece.
      • Underneath. you will locate the motherboard.
      • The tripod piece will be loose. Take the piece from the device and set it off to the side.
      Ask FixBot
    13. Sony Alpha NEX-5N Camera Image Sensor Replacement: step 13, image 1 of 2 Sony Alpha NEX-5N Camera Image Sensor Replacement: step 13, image 2 of 2
      • The top and bottom of the device has ZIF ribbon cable connectors holding the motherboard in place.
      • Flip up the white retaining tabs, and utilize tweezer to, pull out the 2 thin ribbon cables, located on top of the motherboard.
      • Do not touch the ribbons with bare hands.
      Ask FixBot
    14. Sony Alpha NEX-5N Camera Image Sensor Replacement: step 14, image 1 of 3 Sony Alpha NEX-5N Camera Image Sensor Replacement: step 14, image 2 of 3 Sony Alpha NEX-5N Camera Image Sensor Replacement: step 14, image 3 of 3
      Tool used on this step:
      Buy
      • Locate 3 thick ribbon cables on the bottom, and flip up the white retaining tabs. Pull out the remaining ribbon cables, utilizing tweezers.
      Ask FixBot
    15. Sony Alpha NEX-5N Camera Image Sensor Replacement: step 15, image 1 of 2 Sony Alpha NEX-5N Camera Image Sensor Replacement: step 15, image 2 of 2
      • Lift the gray plastic camera piece surrounding the motherboard up.
      • Leave the long, thin ribbon cable that runs along the gray piece attached. It is not necessary to detach.
      • Lift up the motherboard to reveal one final thin ribbon cable connected to a white retaining tab underneath the motherboard.
      • Flip up the white retaining tab, and utilize tweezers to pull out the final thin ribbon cable.
      Ask FixBot
    1. Sony Alpha NEX-5N Camera Image Sensor Replacement, Camera Image Sensor: step 16, image 1 of 2 Sony Alpha NEX-5N Camera Image Sensor Replacement, Camera Image Sensor: step 16, image 2 of 2
      Buy
      • Unscrew 3 black 2.25mm screws, utilizing the screwdriver head PH000, on the metal plate underneath the motherboard.
      • Utilizing a pair of tweezers, remove the metal plate from the device.
      Ask FixBot
    2. Sony Alpha NEX-5N Camera Image Sensor Replacement: step 17, image 1 of 2 Sony Alpha NEX-5N Camera Image Sensor Replacement: step 17, image 2 of 2
      • Detach the circuit board from the device.
      Ask FixBot
    3. Sony Alpha NEX-5N Camera Image Sensor Replacement: step 18, image 1 of 3 Sony Alpha NEX-5N Camera Image Sensor Replacement: step 18, image 2 of 3 Sony Alpha NEX-5N Camera Image Sensor Replacement: step 18, image 3 of 3
      • Unscrew 4 2.25mm Phillips #000 screws on the circuit board.
      • Remove the circuit board from the camera image sensor.
      Ask FixBot
4 other people completed this guide.
Author
with
Tessa Reininger
504 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 171
All Time: 7,435
