Up to 20% off select tools
Sony Alpha NEX-3N Sensor Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
18
Past 30 Days:
95
All Time:
929
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 hours
Difficulty: Difficult
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
    1. Sony Alpha NEX-3N Sensor Replacement, Getting Started: step 1, image 1 of 2 Sony Alpha NEX-3N Sensor Replacement, Getting Started: step 1, image 2 of 2
      • Remove the battery and SD card from the bottom of the camera before starting any disassembly. This is not only to keep your image files safe, but to also prevent getting shocked by electronic components inside the camera.
      Ask FixBot
    2. Sony Alpha NEX-3N Sensor Replacement, Back Case 1: step 2, image 1 of 3 Sony Alpha NEX-3N Sensor Replacement, Back Case 1: step 2, image 2 of 3 Sony Alpha NEX-3N Sensor Replacement, Back Case 1: step 2, image 3 of 3
      • On the right side, remove 1 M1.4x3.7 screw marked with a yellow box.
      • On the left, remove 3 M1.4x3.7 screws also marked by the yellow boxes.
      • On the bottom side, remove 5 M1.4x3.7 screws, including 2 in the battery bay. 2 of them are in this photo; you can find them.
      • Do NOT touch the screws on the bottom of the LCD assembly.
      Ask FixBot
    3. Sony Alpha NEX-3N Sensor Replacement, Back Case 2: step 3, image 1 of 1
      • Pop open the flash.
      • In flash area, remove 1 (one) M1.4x3.8 black screw, marked by the blue box.
      Ask FixBot
    4. Sony Alpha NEX-3N Sensor Replacement, Back Case 3: step 4, image 1 of 3 Sony Alpha NEX-3N Sensor Replacement, Back Case 3: step 4, image 2 of 3 Sony Alpha NEX-3N Sensor Replacement, Back Case 3: step 4, image 3 of 3
      • Remove the LCD hinge cover, by sliding it to the left.
      • Remove the back cover, which is actually just a plastic frame.
      Ask FixBot
    5. Sony Alpha NEX-3N Sensor Replacement, LCD assembly: step 5, image 1 of 2 Sony Alpha NEX-3N Sensor Replacement, LCD assembly: step 5, image 2 of 2
      • Remove 1 M1.4x2 screw marked by the blue box.
      • Remove another M1.4x2 screw. (sorry for the angle of the photo!)
      Ask FixBot
    6. Sony Alpha NEX-3N Sensor Replacement, LCD Assembly: step 6, image 1 of 3 Sony Alpha NEX-3N Sensor Replacement, LCD Assembly: step 6, image 2 of 3 Sony Alpha NEX-3N Sensor Replacement, LCD Assembly: step 6, image 3 of 3
      • CAUTION. Sony makes world's MOST BRITTLE FPC! Use extra care when taking the LCD off to try not to break the FPC.
      • Loosen the LCD assembly with caution!
      • Release the FPC cable, as the connector is a flip type.
      Ask FixBot
    7. Sony Alpha NEX-3N Sensor Replacement, The LCD assembly: step 7, image 1 of 1
      • The LCD assembly when taken out of the camera.
      Ask FixBot
    8. Sony Alpha NEX-3N Sensor Replacement, Dismantle the LCD Part: step 8, image 1 of 3 Sony Alpha NEX-3N Sensor Replacement, Dismantle the LCD Part: step 8, image 2 of 3 Sony Alpha NEX-3N Sensor Replacement, Dismantle the LCD Part: step 8, image 3 of 3
      • After unscrew 4pcs screw, you will remove the steel black plate, then slowly pull the black frame there to see the ribbon stripe.
      • Slowly pull the very fragile ribbon lock, which I marked with the blue boxes. Around just 1mm to unlock the ribbon. Unfortunately, I broke mine.
      Ask FixBot
    9. Sony Alpha NEX-3N Sensor Replacement, Dismantle the LCD Part: step 9, image 1 of 3 Sony Alpha NEX-3N Sensor Replacement, Dismantle the LCD Part: step 9, image 2 of 3 Sony Alpha NEX-3N Sensor Replacement, Dismantle the LCD Part: step 9, image 3 of 3
      • You can see the ribbon has already pulled out. But be careful with the other 2 ribbons when you try to pull out this one.
      • The the circle marker that shows others ribbons you need to be careful. Goodluck!
      Ask FixBot
    1. Sony Alpha NEX-3N Sensor Replacement, Keypad: step 10, image 1 of 3 Sony Alpha NEX-3N Sensor Replacement, Keypad: step 10, image 2 of 3 Sony Alpha NEX-3N Sensor Replacement, Keypad: step 10, image 3 of 3
      • Lift the keypad.
      • Detach FPC
      Ask FixBot
    1. Sony Alpha NEX-3N Sensor Replacement, Screws: step 11, image 1 of 1
      • Remove 3 M1.4x3.6 black screws, 2 of them out of focus
      Ask FixBot
    2. Sony Alpha NEX-3N Sensor Replacement: step 12, image 1 of 2 Sony Alpha NEX-3N Sensor Replacement: step 12, image 2 of 2
      • Slide the flash assembly backwards with caution.
      • Detach flash FPC by pulling it out of the socket.
      • High Voltage! Do NOT touch metal on FPC.
      • Then remove the flash assembly.
      Ask FixBot
    3. Sony Alpha NEX-3N Sensor Replacement: step 13, image 1 of 1
      • Remove that part whatever called, by sliding it backwards.
      Ask FixBot
    1. Sony Alpha NEX-3N Sensor Replacement, Screws: step 14, image 1 of 3 Sony Alpha NEX-3N Sensor Replacement, Screws: step 14, image 2 of 3 Sony Alpha NEX-3N Sensor Replacement, Screws: step 14, image 3 of 3
      • 1 ST1.7x5
      • 2 ST1.7x5
      • 1 M1.4x3.6 black
      Ask FixBot
    2. Sony Alpha NEX-3N Sensor Replacement, The Grip: step 15, image 1 of 2 Sony Alpha NEX-3N Sensor Replacement, The Grip: step 15, image 2 of 2
      • Remove 2 ST1.7x5 screws from inside the battery bay. (one of them not shown, deeper inside) insert screw driver through a hole in the shielding cover.
      • Pop the grip off. From back, push to the right, then it flies forward.
      Ask FixBot
    3. Sony Alpha NEX-3N Sensor Replacement, More Screws: step 16, image 1 of 1
      • Remove 2 M1.4x2 black screws
      Ask FixBot
    4. Sony Alpha NEX-3N Sensor Replacement, Pop the Shielding Cover: step 17, image 1 of 2 Sony Alpha NEX-3N Sensor Replacement, Pop the Shielding Cover: step 17, image 2 of 2
      • with caution and patient.
      Ask FixBot
    5. Sony Alpha NEX-3N Sensor Replacement, One More Shield: step 18, image 1 of 3 Sony Alpha NEX-3N Sensor Replacement, One More Shield: step 18, image 2 of 3 Sony Alpha NEX-3N Sensor Replacement, One More Shield: step 18, image 3 of 3
      • 1 M1.4x3.6
      Ask FixBot
    6. Sony Alpha NEX-3N Sensor Replacement, Detach 7000 FPCs: step 19, image 1 of 1
      • Sensor power, flip
      • Sensor signal, flip
      • Shutter, pull
      • Lens contacts, pull. Did I mention that Sony makes world's most brittle FPC?
      • Whatever, pull
      • Whatever, pull
      • Shutter charger motor FPC, (backside, pull out)
      Ask FixBot
    7. Sony Alpha NEX-3N Sensor Replacement: step 20, image 1 of 1
      • Flip the Mainboard up
      • Pull out one more FPC
      • Discharge then desolder 4 wires.
      • CAUTION! Possible high DC voltage >300V
      Ask FixBot
    8. Sony Alpha NEX-3N Sensor Replacement: step 21, image 1 of 1
      • Lift main board and plastic frame with flash capacitor.
      Ask FixBot
    1. Sony Alpha NEX-3N Sensor Replacement, FPC cables: step 22, image 1 of 1
      • Detach sensor Power (L)and Signal(R) FPC
      Ask FixBot
    2. Sony Alpha NEX-3N Sensor Replacement, Screws: step 23, image 1 of 1
      • Remove 3-4 ST1.7x5 screws
      • Remove 1 M1.4x5 screw
      Ask FixBot
    3. Sony Alpha NEX-3N Sensor Replacement: step 24, image 1 of 2 Sony Alpha NEX-3N Sensor Replacement: step 24, image 2 of 2
      • Remove 4 ST1.7x5 screws for the E-Mount
      • Remove mount metal ring
      Ask FixBot
    4. Sony Alpha NEX-3N Sensor Replacement, E-Mount: step 25, image 1 of 3 Sony Alpha NEX-3N Sensor Replacement, E-Mount: step 25, image 2 of 3 Sony Alpha NEX-3N Sensor Replacement, E-Mount: step 25, image 3 of 3
      • Remove mount plastic ring
      • remove mount spring ring
      Ask FixBot
    5. Sony Alpha NEX-3N Sensor Replacement, Sensor + Shutter: step 26, image 1 of 1
      • Sensor + Shutter assembly comes off
      Ask FixBot
    6. Sony Alpha NEX-3N Sensor Replacement, Sensor Frame: step 27, image 1 of 1
      • Separate sensor + shutter from another frame
      Ask FixBot
    7. Sony Alpha NEX-3N Sensor Replacement, The Sensor: step 28, image 1 of 3 Sony Alpha NEX-3N Sensor Replacement, The Sensor: step 28, image 2 of 3 Sony Alpha NEX-3N Sensor Replacement, The Sensor: step 28, image 3 of 3
      • Remove 3 ST1.7x5 screws
      • Remove sensor shield / heat sink. Sensor PCBA might sticks to the shield, just separate them.
      Ask FixBot
Author
with
Terrance
7,099 Reputation
19 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 18
Past 30 Days: 95
All Time: 929
