Up to 20% off select tools
Sony Alpha ILCE-6000 Screen Replacement
Views: 14K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
169
All Time:
13,628
Comments: 10
6 comments on steps, 4 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
If your screen is cracked, smashed or stopped working, this guide will help you replace the screen for the Sony Alpha ILCE-6000
    1. Sony Alpha ILCE-6000 Screen Replacement, Battery Replacement: step 1, image 1 of 1
      • Turn off the camera by sliding the power switch to OFF.
      Ask FixBot
    2. Sony Alpha ILCE-6000 Screen Replacement: step 2, image 1 of 3 Sony Alpha ILCE-6000 Screen Replacement: step 2, image 2 of 3 Sony Alpha ILCE-6000 Screen Replacement: step 2, image 3 of 3
      • Flip the camera upside down and locate the battery compartment.
      • Slide the compartment lock to OPEN to unlock it.
      Ask FixBot
    3. Sony Alpha ILCE-6000 Screen Replacement: step 3, image 1 of 2 Sony Alpha ILCE-6000 Screen Replacement: step 3, image 2 of 2
      • Locate the blue lever that keeps the battery in place.
      • Push the blue lever back to release battery.
      Ask FixBot
    4. Sony Alpha ILCE-6000 Screen Replacement: step 4, image 1 of 1
      • Once the battery is free, you are able to take the battery out of the compartment.
      Ask FixBot
    1. Sony Alpha ILCE-6000 Screen Replacement, Screen: step 5, image 1 of 3 Sony Alpha ILCE-6000 Screen Replacement, Screen: step 5, image 2 of 3 Sony Alpha ILCE-6000 Screen Replacement, Screen: step 5, image 3 of 3
      • Flip the camera to the bottom side. Using screwdriver, remove the two screws located on the bottom of camera screen.
      • Flip the camera back over, locate the two other 3mm screws behind the screen and remove them.
      Ask FixBot
    2. Sony Alpha ILCE-6000 Screen Replacement: step 6, image 1 of 1
      • Gently pry open the screen backplate.
      Ask FixBot
    3. Sony Alpha ILCE-6000 Screen Replacement: step 7, image 1 of 2 Sony Alpha ILCE-6000 Screen Replacement: step 7, image 2 of 2
      • Gently pry off the plastic cover at the top of the screen.
      Ask FixBot
    4. Sony Alpha ILCE-6000 Screen Replacement: step 8, image 1 of 2 Sony Alpha ILCE-6000 Screen Replacement: step 8, image 2 of 2
      • Carefully remove the clip located at the top of the screen.
      Ask FixBot
    5. Sony Alpha ILCE-6000 Screen Replacement: step 9, image 1 of 1
      • Flip the camera so that it is bottom side up. Pry off the inner support plate.
      Ask FixBot
    6. Sony Alpha ILCE-6000 Screen Replacement: step 10, image 1 of 3 Sony Alpha ILCE-6000 Screen Replacement: step 10, image 2 of 3 Sony Alpha ILCE-6000 Screen Replacement: step 10, image 3 of 3
      • Gently wiggle the screen's ribbon cable until it comes free from the white slot.
      Ask FixBot
    7. Sony Alpha ILCE-6000 Screen Replacement: step 11, image 1 of 1
      • Pry apart the metal backplate and remove it.
      Ask FixBot
    8. Sony Alpha ILCE-6000 Screen Replacement: step 12, image 1 of 2 Sony Alpha ILCE-6000 Screen Replacement: step 12, image 2 of 2
      • Gently remove the old screen, and replace it with the new one.
      Ask FixBot
7 other people completed this guide.
Author
with
Tony Au
423 Reputation
2 Guides authored
UW Tacoma, Team 1-4, Rose Winter 2017 Member of UW Tacoma, Team 1-4, Rose Winter 2017
UWT-ROSE-W17S1G4
4 Members
60 Guides authored
4 Guide Comments
This is super helpful! Where did you purchase your replacement part from?
Claire Sweet - Reply Share
The white connector opens by prying up the black part. What about the little black connector?
Christopher St.Louis - Reply Share
Just comes out when you pull on it gently
Kevin Ketelaars - Reply Share
Top left screw on back plate is a pain to put back in at an angle with magnetized JIS driver. Non magnetized or slightly loose fitting driver might help.
Trick is to get the screw fit in the thread at the right angle, then drive it in with the driver at an angle.
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 169
All Time: 13,628
