Sony Alpha DSLR- A850 Viewfinder Window Replacement
    1. Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Cover: step 1, image 1 of 1
      • Find the rubber viewfinder cover on the upper rear of the camera, above the view screen.
      Ask FixBot
    2. Sony Alpha DSLR- A850 Viewfinder Window Replacement: step 2, image 1 of 1
      • Slide the rubber piece off.
      • There may be a slight popping sound.
      Ask FixBot
    3. Sony Alpha DSLR- A850 Viewfinder Window Replacement: step 3, image 1 of 1
      • Once the rubber piece has been removed, inspect the area.
      • If everything looks fine, go ahead and slide the new rubber piece on the same way the old piece was slipped off.
      Ask FixBot
    1. Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Window: step 4, image 1 of 2 Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Window: step 4, image 2 of 2
      • Remove all four screws from the viewfinder.
      Ask FixBot
    2. Sony Alpha DSLR- A850 Viewfinder Window Replacement: step 5, image 1 of 2 Sony Alpha DSLR- A850 Viewfinder Window Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Grasp the side of the window with either a set of tweezers or your fingers. Lift upwards and slightly towards the base of the camera.
      Ask FixBot
    3. Sony Alpha DSLR- A850 Viewfinder Window Replacement: step 6, image 1 of 1
      • To reinsert the window, push inward and slightly forward. There is a tab on the camera that the window must catch on in order to be put into place.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 22
All Time: 1,044
