Sony Alpha DSLR- A850 Focusing Screen Replacement
    1. Sony Alpha DSLR- A850 Focusing Screen Replacement, Focusing Screen: step 1, image 1 of 3 Sony Alpha DSLR- A850 Focusing Screen Replacement, Focusing Screen: step 1, image 2 of 3 Sony Alpha DSLR- A850 Focusing Screen Replacement, Focusing Screen: step 1, image 3 of 3
      • Push in the button next to the lens.
      • While holding the button twist the lens counter-clockwise.
      • Pull up and remove lens from camera.
      Ask FixBot
    2. Sony Alpha DSLR- A850 Focusing Screen Replacement: step 2, image 1 of 3 Sony Alpha DSLR- A850 Focusing Screen Replacement: step 2, image 2 of 3 Sony Alpha DSLR- A850 Focusing Screen Replacement: step 2, image 3 of 3
      • Inside toward the top you will find a small slit in the plastic piece.
      • Insert a flat head screw driver into the slit and pull down to access the focusing screen.
      Ask FixBot
    3. Sony Alpha DSLR- A850 Focusing Screen Replacement: step 3, image 1 of 3 Sony Alpha DSLR- A850 Focusing Screen Replacement: step 3, image 2 of 3 Sony Alpha DSLR- A850 Focusing Screen Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Using tweezers grab the focusing screen on the side by the two tabs that are on it.
      • Do not grab the focusing screen in the middle as this will damage it.
      • Pull out and remove focusing screen from camera.
      Ask FixBot
    4. Sony Alpha DSLR- A850 Focusing Screen Replacement: step 4, image 1 of 3 Sony Alpha DSLR- A850 Focusing Screen Replacement: step 4, image 2 of 3 Sony Alpha DSLR- A850 Focusing Screen Replacement: step 4, image 3 of 3
      • When inserting new screen make sure to orient it where the two tabs are facing towards you with the smaller tab facing up.
      • Angle the focusing screen to make installation easier.
      • Lay the new focusing screen into the plastic tray.
      • It does not snap into place.
      Ask FixBot
    5. Sony Alpha DSLR- A850 Focusing Screen Replacement: step 5, image 1 of 2 Sony Alpha DSLR- A850 Focusing Screen Replacement: step 5, image 2 of 2
      • Insert screw driver into the slit and push up to close.
      • You can also use your thumb, if you are careful not to touch the screen as this could leave a smudge on it.
      • You will hear a click when the plastic tray is back in place.
      Ask FixBot
    6. Sony Alpha DSLR- A850 Focusing Screen Replacement: step 6, image 1 of 2 Sony Alpha DSLR- A850 Focusing Screen Replacement: step 6, image 2 of 2
      • When re-installing the lens line up the orange dots that are one both lens and camera.
      • Fit lens into place and turn clockwise to secure it back to camera.
      Ask FixBot
You have now completed a focusing screen replacement.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 33
All Time: 1,454
