Sony Alpha A350 Rear Case Replacement
  1. Sony Alpha A350 Rear Case Replacement, Front Case: step 1, image 1 of 2 Sony Alpha A350 Rear Case Replacement, Front Case: step 1, image 2 of 2
    • Using a Phillips #00 Screwdriver, remove the four 5.5mm screws from the bottom of the camera.
    • Using a Phillips #00 Screwdriver, remove the one 4.3mm screw.
    Ask FixBot
  2. Sony Alpha A350 Rear Case Replacement: step 2, image 1 of 2 Sony Alpha A350 Rear Case Replacement: step 2, image 2 of 2
    • Using a Phillips #00 screwdriver, remove one 3.6mm screw on the left side of the camera.
    • Open the remote / DC under the rubber flap to reveal a screw.
    • Using the Phillips #00 screwdriver, remove one 4.3mm screw.
    Ask FixBot
  3. Sony Alpha A350 Rear Case Replacement: step 3, image 1 of 2 Sony Alpha A350 Rear Case Replacement: step 3, image 2 of 2
    • Open the flash on the top of the camera and remove two 4.3mm screws with a Phillips #00 screwdriver.
    • If the spring guard falls out during deconstruction, gently place the guard over the spring during construction.
    • To open the flash, simply press the button on the left side.
    Ask FixBot
  4. Sony Alpha A350 Rear Case Replacement: step 4, image 1 of 2 Sony Alpha A350 Rear Case Replacement: step 4, image 2 of 2
    • Open the plastic SD card door.
    • Using Phillips #00 screwdriver, remove two 4.4 mm screws outside and two 4.4mm screws inside the door.
    Ask FixBot
  5. Sony Alpha A350 Rear Case Replacement: step 5, image 1 of 2 Sony Alpha A350 Rear Case Replacement: step 5, image 2 of 2
    • Gently pull the outer front case from the camera.
    • It should fall apart easily if all screws are removed.
    Ask FixBot
  6. Sony Alpha A350 Rear Case Replacement, Eye Cup: step 6, image 1 of 3 Sony Alpha A350 Rear Case Replacement, Eye Cup: step 6, image 2 of 3 Sony Alpha A350 Rear Case Replacement, Eye Cup: step 6, image 3 of 3
    Tool used on this step:
    Heavy-Duty Spudger
    Buy
    • Identify the bottom of the eye cup
    • Using the heavy duty spudger, push the eye cup upward to remove it from the camera body.
    Ask FixBot
  7. Sony Alpha A350 Rear Case Replacement: step 7, image 1 of 3 Sony Alpha A350 Rear Case Replacement: step 7, image 2 of 3 Sony Alpha A350 Rear Case Replacement: step 7, image 3 of 3
    • Using the Phillips #000 screwdriver, unscrew the two screws from the eye cup.
    • Remove the back side of the eye cup.
    Ask FixBot
  8. Sony Alpha A350 Rear Case Replacement: step 8, image 1 of 3 Sony Alpha A350 Rear Case Replacement: step 8, image 2 of 3 Sony Alpha A350 Rear Case Replacement: step 8, image 3 of 3
    • Push down on the hard plastic part of the eye cup and remove it from the cushion.
    Ask FixBot
  9. Sony Alpha A350 Rear Case Replacement, Rear Case: step 9, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the two 4.3mm screws attaching the ribbons to the front case.
    Ask FixBot
  10. Sony Alpha A350 Rear Case Replacement: step 10, image 1 of 1
    • After taking off the eye cup, remove two screws using a Phillips #00 screwdriver.
    Ask FixBot
  11. Sony Alpha A350 Rear Case Replacement: step 11, image 1 of 2 Sony Alpha A350 Rear Case Replacement: step 11, image 2 of 2
    • Gently pry the rear case off of the body of the camera using your hands or a spudger.
    Ask FixBot
Danielle Trivett
337 Reputation
3 Guides authored
IUPUI, Team S1-G6, Henning Fall 2019 Member of IUPUI, Team S1-G6, Henning Fall 2019
IUPUI-HENNING-F19S1G6
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 45
All Time: 1,616
