Up to 20% off select tools
Sony Alpha A350 Power Switch Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
28
Past 30 Days:
109
All Time:
2,438
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Difficult
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
If your power switch is damaged the best option may be to replace it.
    1. Sony Alpha A350 Power Switch Replacement, Power Switch: step 1, image 1 of 3 Sony Alpha A350 Power Switch Replacement, Power Switch: step 1, image 2 of 3 Sony Alpha A350 Power Switch Replacement, Power Switch: step 1, image 3 of 3
      • Identify and unscrew the ten PH000 screws around the top, front, left, and right sides of the camera body.
      • Screws are very small, can be difficult to remove, and easy to lose.
      Ask FixBot
    2. Sony Alpha A350 Power Switch Replacement: step 2, image 1 of 3 Sony Alpha A350 Power Switch Replacement: step 2, image 2 of 3 Sony Alpha A350 Power Switch Replacement: step 2, image 3 of 3
      • Slowly separate the back case from the camera.
      • There may be a ribbon cable connecting the two pieces. Unlock the connector and remove the ribbon cable if necessary.
      • Idenify and unscrew the two PH000 screws connecting the power switch.
      • Remove the power switch.
      Ask FixBot
Author
with
Sydney Duncan
820 Reputation
5 Guides authored
CJLADIES Member of CJLADIES
Community
1 Member
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 109
All Time: 2,438
