Sony Alpha A350 Front Case Replacement
    1. Sony Alpha A350 Front Case Replacement, Front Case: step 1, image 1 of 2 Sony Alpha A350 Front Case Replacement, Front Case: step 1, image 2 of 2
      • Using a Phillips #00 Screwdriver, remove the four 5.5mm screws from the bottom of the camera.
      • Using a Phillips #00 Screwdriver, remove the one 4.3mm screw.
      Ask FixBot
    2. Sony Alpha A350 Front Case Replacement: step 2, image 1 of 2 Sony Alpha A350 Front Case Replacement: step 2, image 2 of 2
      • Using a Phillips #00 screwdriver, remove one 3.6mm screw on the left side of the camera.
      • Open the remote / DC under the rubber flap to reveal a screw.
      • Using the Phillips #00 screwdriver, remove one 4.3mm screw.
      Ask FixBot
    3. Sony Alpha A350 Front Case Replacement: step 3, image 1 of 2 Sony Alpha A350 Front Case Replacement: step 3, image 2 of 2
      • Open the flash on the top of the camera and remove two 4.3mm screws with a Phillips #00 screwdriver.
      • If the spring guard falls out during deconstruction, gently place the guard over the spring during construction.
      • To open the flash, simply press the button on the left side.
      Ask FixBot
    4. Sony Alpha A350 Front Case Replacement: step 4, image 1 of 2 Sony Alpha A350 Front Case Replacement: step 4, image 2 of 2
      • Open the plastic SD card door.
      • Using Phillips #00 screwdriver, remove two 4.4 mm screws outside and two 4.4mm screws inside the door.
      Ask FixBot
    5. Sony Alpha A350 Front Case Replacement: step 5, image 1 of 2 Sony Alpha A350 Front Case Replacement: step 5, image 2 of 2
      • Gently pull the outer front case from the camera.
      • It should fall apart easily if all screws are removed.
      Ask FixBot
Danielle Trivett
337 Reputation
3 Guides authored
IUPUI, Team S1-G6, Henning Fall 2019 Member of IUPUI, Team S1-G6, Henning Fall 2019
IUPUI-HENNING-F19S1G6
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 30
All Time: 1,425
