Community-Contributed Guide
Introduction
Go to step 1 ↓My camera was auto focusing only after power-up, all menu buttons were not active (there was a workaround of switching camera mode e.g. A->P to enter the main menu). Taking photos was still possible.
That were results of stucked first action circuit of the shutter button: camera was constantly detecting slight press of the button leading to that strange behaviour.
Hopefully I found the microswitch replacement at mouser. Costs only ~2Euro and is fully compatible or even same as used in factory.
Ifixit helped me with disassembly, now I'm paying off describing this guide.
After removing the backing from the camera. Remove the two final screws in the memory compartment area.
Detach the facing for the memory dock.
Pull out the capacitor and move the capacitor board (flexible) to the left to clear the way for future steps.
Move the Program Dial to P.
Remove two screws mounting plastic buttons module.
Remove the module.
Replace the ALPS SKSDPCE010 microswitch. Look out for the correct allignment and orientation (first pin marked with a dot).
5 Guide Comments
Excellent article, I would like to know what should be done to replace or repair the mode selector of the camera, (Dial mode) I appreciate this great contribution. Greetings.
Mode selector switch is visible on 2 photos of buttons module PCB. Look for a switch with blue knob on 2nd Photo of step 16. I dont know the serial number or replacement.
Thank you so much for reply.
I used this guide to check on the switch (marked "336L") next to the shutter button. My a3000 only turns on after messing a bit with the ON/OFF switch. I sprayed TermoPasty Kontakt PR on it and did a little exercise. I'll assemble again and test. Anyone had a similar problem?
@guilhermem25442 And I can confirm the cleaning worked!
