Sony Alpha A3000 Motherboard Replacement
Views: 3.5K
View statistics:
Past 24 Hours:
6
Past 7 Days:
31
Past 30 Days:
120
All Time:
3,484
Comments: 1
1 guide comment.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide provided instruction on removing the motherboard and should only be followed if a compatible replacement is available or subsequent repair procedures require its removal.
Tools
    1. Sony Alpha A3000 Motherboard Replacement, Rear Case: step 1, image 1 of 3 Sony Alpha A3000 Motherboard Replacement, Rear Case: step 1, image 2 of 3 Sony Alpha A3000 Motherboard Replacement, Rear Case: step 1, image 3 of 3
      • Remove the seven highlighted screws shown here.
      • Screws are teeny tiny, don't lose them!
      Ask FixBot
    2. Sony Alpha A3000 Motherboard Replacement: step 2, image 1 of 2 Sony Alpha A3000 Motherboard Replacement: step 2, image 2 of 2
      • Remove this final screw from the memory card compartment.
      • Remove the chassis by pulling the back cover away from the camera.
      • Be careful not to damage any of the delicate ribbon cables when removing the chassis.
      Ask FixBot
    3. Sony Alpha A3000 Motherboard Replacement: step 3, image 1 of 2 Sony Alpha A3000 Motherboard Replacement: step 3, image 2 of 2
      • Gently but forcefully lift up on the parallel cable connecting the two halves of the camera.
      Ask FixBot
    1. Sony Alpha A3000 Motherboard Replacement, Motherboard: step 4, image 1 of 2 Sony Alpha A3000 Motherboard Replacement, Motherboard: step 4, image 2 of 2
      • After removing the backing from the camera. Remove the two final screws in the memory compartment area.
      • Detach the facing for the memory dock.
      Ask FixBot
    2. Sony Alpha A3000 Motherboard Replacement: step 5, image 1 of 2 Sony Alpha A3000 Motherboard Replacement: step 5, image 2 of 2
      • Remove the eight screws securing the mount for the flash device.
      Ask FixBot
    3. Sony Alpha A3000 Motherboard Replacement: step 6, image 1 of 2 Sony Alpha A3000 Motherboard Replacement: step 6, image 2 of 2
      • Remove the three remaining screws holding in the protective metal casing.
      Ask FixBot
    4. Sony Alpha A3000 Motherboard Replacement: step 7, image 1 of 1
      • Remove the metal casing.
      Ask FixBot
    5. Sony Alpha A3000 Motherboard Replacement: step 8, image 1 of 1
      • Remove three screws holding down the motherboard .
      Ask FixBot
    6. Sony Alpha A3000 Motherboard Replacement: step 9, image 1 of 2 Sony Alpha A3000 Motherboard Replacement: step 9, image 2 of 2
      • Detach the nine serial cables connecting it to the camera body.
      Ask FixBot
    7. Sony Alpha A3000 Motherboard Replacement: step 10, image 1 of 1
      • Finally remove the motherboard from the casing.
      Ask FixBot
8 other people completed this guide.
Leonard Holloman
662 Reputation
4 Guides authored
USF Tampa, Team 4-4, Meier Fall 2015 Member of USF Tampa, Team 4-4, Meier Fall 2015
USFT-MEIER-F15S4G4
4 Members
60 Guides authored
1 Guide Comment
Then loose the plug all the motherboard?
kongre172 - Reply Share
Past 24 Hours: 6
Past 7 Days: 31
Past 30 Days: 120
All Time: 3,484
