Sony Alpha A3000 Built-in flash Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
96
All Time:
2,933
Comments: 4
4 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide shows how to remove the build-in flash of the camera from its compartment. You will need a soldering tool to detach the cables connecting the flash to the camera.
Tools
    1. Sony Alpha A3000 Built-in flash Replacement, Rear Case: step 1, image 1 of 3 Sony Alpha A3000 Built-in flash Replacement, Rear Case: step 1, image 2 of 3 Sony Alpha A3000 Built-in flash Replacement, Rear Case: step 1, image 3 of 3
      • Remove the seven highlighted screws shown here.
      • Screws are teeny tiny, don't lose them!
      Ask FixBot
    2. Sony Alpha A3000 Built-in flash Replacement: step 2, image 1 of 2 Sony Alpha A3000 Built-in flash Replacement: step 2, image 2 of 2
      • Remove this final screw from the memory card compartment.
      • Remove the chassis by pulling the back cover away from the camera.
      • Be careful not to damage any of the delicate ribbon cables when removing the chassis.
      Ask FixBot
    3. Sony Alpha A3000 Built-in flash Replacement: step 3, image 1 of 2 Sony Alpha A3000 Built-in flash Replacement: step 3, image 2 of 2
      • Gently but forcefully lift up on the parallel cable connecting the two halves of the camera.
      Ask FixBot
    1. Sony Alpha A3000 Built-in flash Replacement, Built-in flash: step 4, image 1 of 1
      • Remove the single screw from the bottom of the flash device.
      Ask FixBot
    2. Sony Alpha A3000 Built-in flash Replacement: step 5, image 1 of 1
      • Remove the flash cover by gently pulling it in an outward direction.
      Ask FixBot
    3. Sony Alpha A3000 Built-in flash Replacement: step 6, image 1 of 1
      • Use a soldering tool to remove the three wires connecting the flash to the camera.
      Ask FixBot
2 other people completed this guide.
Leonard Holloman
662 Reputation
4 Guides authored
USF Tampa, Team 4-4, Meier Fall 2015 Member of USF Tampa, Team 4-4, Meier Fall 2015
USFT-MEIER-F15S4G4
4 Members
60 Guides authored
4 Guide Comments
Thx, saved me from draing costs for cleaning my viewfinder from watercolor paint. also hotshoe adapter disassembly was easier than other parts. be careful, if you want to do it!
Michael Smith - Reply Share
My LCD and viewfinder are not working anymore. I think is the flex that broke up... or the socket where is connected... And there is no replacement pieces in my country.......... As well as it is not a cheap camera for us........ I want to kill myself.........................
l2weenlive - Reply Share
Any procedure for SONY a6300 built-in flash replacement?
Vivek Dhar - Reply Share
hi, i see this thread a bit old. has someone replaced the focus assist light (that orange tint ?LED?).
mine missing since i have my cam. regardless of menu setting, it never lighted up.
dont have clue, how deeply should blow up, till access.
Levente Likhanecz - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 96
All Time: 2,933
