Up to 20% off select tools
Sony Alpha 6000 Shutter Button Replacement
Views: 21K
View statistics:
Past 24 Hours:
6
Past 7 Days:
55
Past 30 Days:
289
All Time:
21,053
Comments: 15
11 comments on steps, 4 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Difficult
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Tools
Introduction
Go to step 1 ↓
If there are problems with the camera recognizing the press of the shutter button, this guide will show you step-by-step instructions on how to remove the button in order to replace it.
    1. Sony Alpha 6000 Shutter Button Replacement, Battery: step 1, image 1 of 1
      • Make sure the camera is turned off by turning the switch to OFF.
      Ask FixBot
    2. Sony Alpha 6000 Shutter Button Replacement: step 2, image 1 of 1
      • Flip the camera around to access the battery compartment.
      • Slide the battery compartment lock to the left to unlock it.
      Ask FixBot
    3. Sony Alpha 6000 Shutter Button Replacement: step 3, image 1 of 1
      • Locate the blue latch that holds the battery in.
      Ask FixBot
    4. Sony Alpha 6000 Shutter Button Replacement: step 4, image 1 of 1
      • Push the latch back to release battery.
      Ask FixBot
    5. Sony Alpha 6000 Shutter Button Replacement: step 5, image 1 of 1
      • The battery can now be taken out of its compartment.
      Ask FixBot
    1. Sony Alpha 6000 Shutter Button Replacement, Back Cover: step 6, image 1 of 1
      • Turn the camera upside down and unscrew these two bottom 6 mm screws located on either side of the body by using the J00 head screw.
      Ask FixBot
    2. Sony Alpha 6000 Shutter Button Replacement: step 7, image 1 of 1
      • Turn the camera sideways.
      • Open the mini HDMI compartment and locate the two 6 mm screw underneath and another to the right of the compartment.
      • Unscrew using the J00 head screw.
      Ask FixBot
    3. Sony Alpha 6000 Shutter Button Replacement: step 8, image 1 of 1
      • Locate the two 4 mm screws within the battery compartment and unscrew them using the J00 screw head.
      Ask FixBot
    4. Sony Alpha 6000 Shutter Button Replacement: step 9, image 1 of 1
      • Bend the camera's screen forward to uncover two 3 mm screws below the eyepiece.
      • Locate them and unscrew them.
      Ask FixBot
    5. Sony Alpha 6000 Shutter Button Replacement: step 10, image 1 of 2 Sony Alpha 6000 Shutter Button Replacement: step 10, image 2 of 2
      • Use a plastic opening tool around the body of the camera to wedge the back cover off. Start from the bottom next to the battery compartment.
      • If necessary, lightly use your hand to pull the the back cover down to completely remove it.
      Ask FixBot
    1. Sony Alpha 6000 Shutter Button Replacement, Shutter Button: step 11, image 1 of 1
      • Once the back cover is off, locate the flash of the camera and push it forward to open it
      Ask FixBot
    2. Sony Alpha 6000 Shutter Button Replacement: step 12, image 1 of 1
      • Locate the two 3 mm screws within the flash and unscrew them
      Ask FixBot
    3. Sony Alpha 6000 Shutter Button Replacement: step 13, image 1 of 1
      • Hold the camera from the bottom and using a spudger, go around the top of the camera and separate the top plastic piece from the main body.
      Ask FixBot
    4. Sony Alpha 6000 Shutter Button Replacement: step 14, image 1 of 2 Sony Alpha 6000 Shutter Button Replacement: step 14, image 2 of 2
      • Hold the top of the camera away from the body.
      • Carefully turn it over to uncover the bottom of the shutter button.
      Ask FixBot
    5. Sony Alpha 6000 Shutter Button Replacement: step 15, image 1 of 1
      • Locate the two screws holding the shutter button and unscrew them.
      Ask FixBot
    6. Sony Alpha 6000 Shutter Button Replacement: step 16, image 1 of 1
      Tool used on this step:
      Buy
      • Once the screws are out, use a pair of tweezers to pull out the circular metal piece under the shutter button.
      Ask FixBot
    7. Sony Alpha 6000 Shutter Button Replacement: step 17, image 1 of 1
      • Turn the top plastic piece back over.
      • Now you will be able to completely remove the camera's shutter button.
      Ask FixBot
Now that the shutter button is removed, you will be able to replace it with a new piece. To reassemble your device, follow these instructions in reverse order.
7 other people completed this guide.
Author
with
Fernando Sierra
400 Reputation
2 Guides authored
USF Tampa, Team 4-5, Passmore Fall 2016 Member of USF Tampa, Team 4-5, Passmore Fall 2016
USFT-PASSMORE-F16S4G5
3 Members
72 Guides authored
4 Guide Comments
Check also https://www.youtube.com/watch?v=y3CCJtD0...
You don't need to remove the back cover (and don't try it because first, you need to remove the top cover...)
Philippe Combronde - Reply Share
Where can i buy a replacement button?
Simon Lundh - Reply Share
You can find the flexible cable with the shutter button on aliexpress:
https://www.aliexpress.com/store/product...
Lac Uster - Reply Share
Thank you!
Arshad kltn - Reply Share
Past 24 Hours: 6
Past 7 Days: 55
Past 30 Days: 289
All Time: 21,053
