Up to 20% off select tools
Sony Alpha 6000 Battery Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
49
All Time:
1,849
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Introduction
Go to step 1 ↓
If the battery of your Sony Alpha 6000 is dead, or if you suspect their is foreign material obstructing the battery compartment, this guide will help in showing how to access and remove the battery.
    1. Sony Alpha 6000 Battery Replacement, Battery: step 1, image 1 of 1
      • Make sure the camera is turned off by turning the switch to OFF.
      Ask FixBot
    2. Sony Alpha 6000 Battery Replacement: step 2, image 1 of 1
      • Flip the camera around to access the battery compartment.
      • Slide the battery compartment lock to the left to unlock it.
      Ask FixBot
    3. Sony Alpha 6000 Battery Replacement: step 3, image 1 of 1
      • Locate the blue latch that holds the battery in.
      Ask FixBot
    4. Sony Alpha 6000 Battery Replacement: step 4, image 1 of 1
      • Push the latch back to release battery.
      Ask FixBot
    5. Sony Alpha 6000 Battery Replacement: step 5, image 1 of 1
      • The battery can now be taken out of its compartment.
      Ask FixBot
Once the battery is out and the compartment is free of any foreign debris, replace it with a new and fully charged one.
Author
with
Jennifer Vuu
548 Reputation
3 Guides authored
USF Tampa, Team 4-5, Passmore Fall 2016 Member of USF Tampa, Team 4-5, Passmore Fall 2016
USFT-PASSMORE-F16S4G5
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 49
All Time: 1,849
