Sony Alpha 5100 LCD Replacement
    1. Sony Alpha 5100 LCD Replacement, LCD: step 1, image 1 of 1
      • Slide the power switch on the top of the camera to "off."
      Ask FixBot
    2. Sony Alpha 5100 LCD Replacement: step 2, image 1 of 1
      • Flip the LCD screen so that you have access to the back of the screen. The front of the screen should be facing the direction that the lens is facing.
      Ask FixBot
    3. Sony Alpha 5100 LCD Replacement: step 3, image 1 of 2 Sony Alpha 5100 LCD Replacement: step 3, image 2 of 2
      • Remove the two 2mm Phillips #00 screws on the back of the screen.
      • Remove the two 2mm Phillips #00 screws on the top of the LCD screen.
      Ask FixBot
    4. Sony Alpha 5100 LCD Replacement: step 4, image 1 of 1
      • Carefully pry open the back plate off the screen with an iFixit opening tool.
      • If separating the plates is giving you trouble, aim for the notch at the bottom of the plate.
      Ask FixBot
    5. Sony Alpha 5100 LCD Replacement: step 5, image 1 of 2 Sony Alpha 5100 LCD Replacement: step 5, image 2 of 2
      • Carefully open the back plate of the screen.
      Ask FixBot
3 other people completed this guide.
Kevin Raggiani
444 Reputation
3 Guides authored
1 Guide Comment
Hello, thank you for this but it’s only half the steps, how to remove the LCD and touch screen after step 5? Something else is holding it in place. Can lift the outer edge a little only. Possibly it is glue or tape? My touchscreen is always active and focus rectangle moving around the lower part of screen. Can touch screen and it will go there but soon moves back to lower area.
Thank you.
John Meldrum - Reply Share
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 60
All Time: 2,926
