Sony AZ1VR Speaker Replacement
    1. Sony AZ1VR Speaker Replacement, Speaker: step 1, image 1 of 2 Sony AZ1VR Speaker Replacement, Speaker: step 1, image 2 of 2
      • Start by removing the two screws on the bottom of the device using your small screwdriver, which should reveal the battery room.
      • Remove the screw inside the battery room.
      • Save these screws for later so they can be used to reassemble.
      Ask FixBot
    2. Sony AZ1VR Speaker Replacement: step 2, image 1 of 1
      • Once these are removed, slide the door out in the direction away from the screw holes.
      • Slide out the small piece of plastic with the door.
      Ask FixBot
    3. Sony AZ1VR Speaker Replacement: step 3, image 1 of 1
      • Now, locate the lens, the large domed piece in the front.
      • Grab the lens and pull the body gently out of the plastic. This will reveal the insides of the device.
      Ask FixBot
    4. Sony AZ1VR Speaker Replacement: step 4, image 1 of 1
      • You'll see a screw on the top of the lens casing, in the white plastic towards the front. Remove this screw.
      Ask FixBot
    5. Sony AZ1VR Speaker Replacement: step 5, image 1 of 2 Sony AZ1VR Speaker Replacement: step 5, image 2 of 2
      • Next pull the tabs on the bottom and top of the lens, and pull outward, this will remove the lens housing from the body.
      • Once removed, flip the device onto its side, leaving the LCD display facing up. This will be the side with the silver metal panel and rectangular screen.
      Ask FixBot
    6. Sony AZ1VR Speaker Replacement: step 6, image 1 of 1
      • Carefully remove the screws connected to the silver metal plate.
      • Once done, remove the plate by pulling gently up on the back of the plate (the back end of the lens unit) and pushing it towards the front (the lens). It should slide out without too much resistance.
      Ask FixBot
    7. Sony AZ1VR Speaker Replacement: step 7, image 1 of 2 Sony AZ1VR Speaker Replacement: step 7, image 2 of 2
      • Now remove the screw directly above the LCD display, the thin rectangle near the rear of the lens unit. This will loosen the black plastic casing over the internal circuitry.
      • Pull the plastic up gently, it will be connected by cables on the bottom. Do not completely remove this plastic, leave it hinged onto the frame.
      Ask FixBot
    8. Sony AZ1VR Speaker Replacement: step 8, image 1 of 1
      • Use the spudger or other nondamaging tool to disconnect the speaker from the unit. This is done at the connection between the yellow cord/ribbon and the motherboard.
      • Remove the speaker from the plastic housing.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. New speaker should be installed and connected in the same connection point as the previous speaker.
Michael Martin
401 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 23
All Time: 385
