Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓This guide will take you through the replacement of a microphone unit in the Sony AZ1VR camcorder. This camcorder is designed to record both video and audio, and provide playback. Audio recording issues can be caused by problems with the connection, assembly, or the unit itself. Resolving this may require repair or replacement, and details the steps of both.
Start by removing the two screws on the bottom of the device using your small screwdriver, which should reveal the battery room.
Remove the screw inside the battery room.
Save these screws for later so they can be used to reassemble.
Next unsolder the microphone cables from the board using the soldering iron. This can be accomplished by heating the existing soldered areas with the iron until they liquify and removing the connecting components.
Keep track of where each wire was soldered, and replace with the same wire in the new part. You can resolder them to the spots by reheating the area until the metal liquifies and placing the wire in.
