Sony AZ1VR Lens O Ring Replacement
  1. Sony AZ1VR Lens O Ring Replacement, Lens O Ring: step 1, image 1 of 3 Sony AZ1VR Lens O Ring Replacement, Lens O Ring: step 1, image 2 of 3 Sony AZ1VR Lens O Ring Replacement, Lens O Ring: step 1, image 3 of 3
    • Start by removing the two screws on the bottom, and the screw inside the battery room.
    • Once these are removed, slide the door out, and the small piece of plastic with the door.
    Ask FixBot
  2. Sony AZ1VR Lens O Ring Replacement: step 2, image 1 of 3 Sony AZ1VR Lens O Ring Replacement: step 2, image 2 of 3 Sony AZ1VR Lens O Ring Replacement: step 2, image 3 of 3
    • Now, grab the lens and pull the body out of the plastic, this will reveal the insides of the device.
    • You'll see a screw on the top of the device, towards the front, remove this screw.
    • Next pull the tabs on the bottom and top of the lens, and pull outward, this will remove the lens housing from the body.
    Ask FixBot
  3. Sony AZ1VR Lens O Ring Replacement: step 3, image 1 of 1
    • Next, you'll see a white ring around the lens, slowly remove that ring without causing damage to the device.
    • Now put the new one in its place. Now reassemble the device, it's all set to be used.
    Ask FixBot
Michael Martin
401 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 29
All Time: 489
