Sony AZ1VR LCD Side Display Replacement
    1. Sony AZ1VR LCD Side Display Replacement, LCD Side Display: step 1, image 1 of 3 Sony AZ1VR LCD Side Display Replacement, LCD Side Display: step 1, image 2 of 3 Sony AZ1VR LCD Side Display Replacement, LCD Side Display: step 1, image 3 of 3
      • Remove the two screws on the bottom of the camera.
      • Remove the screw inside the battery door.
      • Once these are removed, slide the door out, and the small piece of plastic with the door.
      Ask FixBot
    2. Sony AZ1VR LCD Side Display Replacement: step 2, image 1 of 3 Sony AZ1VR LCD Side Display Replacement: step 2, image 2 of 3 Sony AZ1VR LCD Side Display Replacement: step 2, image 3 of 3
      • Grab the lens and pull the body out of the plastic, this will reveal the insides of the device.
      • You'll see a screw on the top of the device, towards the front, remove this screw.
      • Pull the tabs on the bottom and top of the lens, and pull outward, this will remove the lens housing from the body.
      Ask FixBot
    3. Sony AZ1VR LCD Side Display Replacement: step 3, image 1 of 3 Sony AZ1VR LCD Side Display Replacement: step 3, image 2 of 3 Sony AZ1VR LCD Side Display Replacement: step 3, image 3 of 3
      • Remove the screws connected to the silver metal plate.
      • Remove the plate by pulling the back up and pushing it towards the front.
      • Remove the screw directly above the LCD display.
      • Pull the plastic up gently, it will be connected by cables on the bottom.
      • Disconnect the cable going to the LCD display.
      Ask FixBot
Michael Martin
401 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 15
All Time: 373
