Sony α6500 Top Assembly Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
90
All Time:
2,237
Comments: 9
8 comments on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If the top of your camera is damaged or broken, this guide will walk you through its replacement. The removal of the top of the camera is also a prerequisite for the replacement of the flash unit, memory card reader, motherboard, viewfinder glass, and other complex components. You will require a JIS 0 screwdriver, JIS 00 screwdriver, JIS 000 screwdriver, tweezers, and opening tools.
Tools
    1. Sony α6500 Top Assembly Replacement, Battery: step 1, image 1 of 1
      • Verify the camera is powered off by setting the switch to OFF.
      Ask FixBot
    2. Sony α6500 Top Assembly Replacement: step 2, image 1 of 2 Sony α6500 Top Assembly Replacement: step 2, image 2 of 2
      • Flip the camera upside down.
      • Slide the battery compartment lock to OPEN to unlock it.
      Ask FixBot
    3. Sony α6500 Top Assembly Replacement: step 3, image 1 of 2 Sony α6500 Top Assembly Replacement: step 3, image 2 of 2
      • Push the blue lever aside to release the battery.
      Ask FixBot
    4. Sony α6500 Top Assembly Replacement: step 4, image 1 of 1
      • Remove the released battery from the compartment.
      Ask FixBot
    1. Sony α6500 Top Assembly Replacement, Top Assembly: step 5, image 1 of 2 Sony α6500 Top Assembly Replacement, Top Assembly: step 5, image 2 of 2
      • To access the back of the camera remove the screws attaching the LCD screen hinge to the camera body.
      • Remove four 3 mm JIS 000 screws.
      • Remove one 3 mm JIS 00 screw.
      • After dismounting the screen hinge be careful to avoid tearing the black wire ribbon connecting the screen to the camera body.
      Ask FixBot
    2. Sony α6500 Top Assembly Replacement: step 6, image 1 of 2 Sony α6500 Top Assembly Replacement: step 6, image 2 of 2
      • Grasp the viewfinder eyecup; slide it up and off the viewfinder.
      Ask FixBot
    3. Sony α6500 Top Assembly Replacement: step 7, image 1 of 3 Sony α6500 Top Assembly Replacement: step 7, image 2 of 3 Sony α6500 Top Assembly Replacement: step 7, image 3 of 3
      • Press the flash popup button on the back of the camera.
      • Remove one 5 mm JIS 00 screw from inside the flash compartment.
      • Remove one 4 mm JIS 00 screw.
      Ask FixBot
    4. Sony α6500 Top Assembly Replacement: step 8, image 1 of 3 Sony α6500 Top Assembly Replacement: step 8, image 2 of 3 Sony α6500 Top Assembly Replacement: step 8, image 3 of 3
      • To remove the top of the camera you must remove the back first.
      • Remove the 2.5 mm JIS 00 screw from the side of the camera near the viewfinder.
      • Use the opening tool to pry off the small cover.
      • Remove two 2.5 mm JIS 00 screws from underneath the cover.
      • Remove a 5 mm JIS 00 screw from underneath the cover.
      Ask FixBot
    5. Sony α6500 Top Assembly Replacement: step 9, image 1 of 2 Sony α6500 Top Assembly Replacement: step 9, image 2 of 2
      • Remove three 2.5 mm JIS 0 screws from the back face of the camera.
      • Remove one 4 mm JIS 00 screw from the underside of the lip that overhangs the back of the camera.
      Ask FixBot
    6. Sony α6500 Top Assembly Replacement: step 10, image 1 of 1
      • Remove four 4 mm JIS 0 screws from the bottom of the camera.
      Ask FixBot
    7. Sony α6500 Top Assembly Replacement: step 11, image 1 of 2 Sony α6500 Top Assembly Replacement: step 11, image 2 of 2
      • Flip the battery lock switch to open and open the battery compartment.
      • Remove three 2.5 mm JIS 00 screws from the top of the battery compartment.
      • You may need a longer or thinner screwdriver to reach the screws in the battery compartment.
      Ask FixBot
    8. Sony α6500 Top Assembly Replacement: step 12, image 1 of 2 Sony α6500 Top Assembly Replacement: step 12, image 2 of 2
      • Use the plastic opening tool to begin prying off the back of the camera from the side.
      • Continue to loosen the back until you can open it from the bottom.
      Ask FixBot
    9. Sony α6500 Top Assembly Replacement: step 13, image 1 of 3 Sony α6500 Top Assembly Replacement: step 13, image 2 of 3 Sony α6500 Top Assembly Replacement: step 13, image 3 of 3
      Tool used on this step:
      Buy
      • Open the back of the camera.
      • Use tweezers to remove two ribbon connectors from underneath the back. One connects to the LCD display and the other connects to the right side behind the battery compartment.
      • Ribbon connectors can tear easily. Grasp the plastic ends (not the ribbon) when removing.
      Ask FixBot
    10. Sony α6500 Top Assembly Replacement: step 14, image 1 of 3 Sony α6500 Top Assembly Replacement: step 14, image 2 of 3 Sony α6500 Top Assembly Replacement: step 14, image 3 of 3
      • Use the plastic opening tool to peel down the rubber grip around the handle at least 1 cm.
      • The adhesive holding the rubber grip down should be strong enough to reattach when you are done. If not, you may need an adhesive to reglue it.
      • Remove one 3 mm JIS 000 screw from underneath the rubber grip on the right side.
      • Remove one 4 mm JIS 000 screw from the left side.
      Ask FixBot
    11. Sony α6500 Top Assembly Replacement: step 15, image 1 of 2 Sony α6500 Top Assembly Replacement: step 15, image 2 of 2
      • The last screws holding the top on can be accessed once the back of the camera is removed.
      • Remove one 2.5 mm JIS 00 screw from the top next to the flash mount.
      Ask FixBot
    12. Sony α6500 Top Assembly Replacement: step 16, image 1 of 3 Sony α6500 Top Assembly Replacement: step 16, image 2 of 3 Sony α6500 Top Assembly Replacement: step 16, image 3 of 3
      • Insert a long, thin JIS 00 screwdriver through the two holes and into the battery compartment; remove the two 5mm JIS 00 screws inside it.
      Ask FixBot
    13. Sony α6500 Top Assembly Replacement: step 17, image 1 of 2 Sony α6500 Top Assembly Replacement: step 17, image 2 of 2
      • Use the long, thin, screwdriver to remove one 5 mm JIS 00 screw inside the camera accessible below the dials from the back.
      Ask FixBot
    14. Sony α6500 Top Assembly Replacement: step 18, image 1 of 3 Sony α6500 Top Assembly Replacement: step 18, image 2 of 3 Sony α6500 Top Assembly Replacement: step 18, image 3 of 3
      • Use the plastic opening tool to gently lift up the shutter button assembly.
      • Grasp the front grip from the top and bottom and pull it off. It should come off easily with the shutter button out of the way.
      • The shutter button will still be attached by one ribbon cable once the front grip is removed.
      Ask FixBot
    15. Sony α6500 Top Assembly Replacement: step 19, image 1 of 3 Sony α6500 Top Assembly Replacement: step 19, image 2 of 3 Sony α6500 Top Assembly Replacement: step 19, image 3 of 3
      • Remove one 2.5 mm JIS 00 screw from where the shutter button assembly used to be.
      • Remove one 3 mm JIS 00 screw from the side of the camera.
      Ask FixBot
    16. Sony α6500 Top Assembly Replacement: step 20, image 1 of 2 Sony α6500 Top Assembly Replacement: step 20, image 2 of 2
      • Carefully unplug the two ribbon connectors attaching the top assembly to the rest of the camera.
      Ask FixBot
5 other people completed this guide.
Micah Fitzgerald
674 Reputation
2 Guides authored
Cal Poly, Team S11-G5, Regan Fall 2019 Member of Cal Poly, Team S11-G5, Regan Fall 2019
CPSU-REGAN-F19S11G5
5 Members
84 Guides authored
1 Guide Comment
Do you know where i should buy this? Especially in Indonesia.
Dimasngehe - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 90
All Time: 2,237
