Sony α6500 LCD Screen Replacement
    1. Sony α6500 LCD Screen Replacement, Battery: step 1, image 1 of 1
      • Verify the camera is powered off by setting the switch to OFF.
      Ask FixBot
    2. Sony α6500 LCD Screen Replacement: step 2, image 1 of 2 Sony α6500 LCD Screen Replacement: step 2, image 2 of 2
      • Flip the camera upside down.
      • Slide the battery compartment lock to OPEN to unlock it.
      Ask FixBot
    3. Sony α6500 LCD Screen Replacement: step 3, image 1 of 2 Sony α6500 LCD Screen Replacement: step 3, image 2 of 2
      • Push the blue lever aside to release the battery.
      Ask FixBot
    4. Sony α6500 LCD Screen Replacement: step 4, image 1 of 1
      • Remove the released battery from the compartment.
      Ask FixBot
    1. Sony α6500 LCD Screen Replacement, LCD Screen: step 5, image 1 of 3 Sony α6500 LCD Screen Replacement, LCD Screen: step 5, image 2 of 3 Sony α6500 LCD Screen Replacement, LCD Screen: step 5, image 3 of 3
      • To access the LCD assembly we need to remove the screws attaching its hinge to the camera body.
      • Remove four 3mm JIS 000 screws.
      • Remove one 3mm JIS 00 screw.
      • After dismounting the screen hinge be careful to not tear the black wire ribbon connecting the screen to the camera body.
      Ask FixBot
    2. Sony α6500 LCD Screen Replacement: step 6, image 1 of 2 Sony α6500 LCD Screen Replacement: step 6, image 2 of 2
      • Remove the screen hinge from the camera.
      • Be careful to not tear the black flat cable connecting the lcd screen to the main body of the camera. This particular camera's cable has been cut for demonstration purposes.
      Ask FixBot
    3. Sony α6500 LCD Screen Replacement: step 7, image 1 of 1
      • Flip the LCD screen up.
      • Remove two 2mm JIS 000 screws on the bottom edge.
      Ask FixBot
    4. Sony α6500 LCD Screen Replacement: step 8, image 1 of 2 Sony α6500 LCD Screen Replacement: step 8, image 2 of 2
      • Flip the LCD screen down to access the back side.
      • Remove two 2mm JIS 000 screws to release the back panel of the screen.
      Ask FixBot
    5. Sony α6500 LCD Screen Replacement: step 9, image 1 of 2 Sony α6500 LCD Screen Replacement: step 9, image 2 of 2
      • Use the opening tool to pry open the back panel.
      • Remove the black plastic spacer laying on top of the circuit board.
      Ask FixBot
    6. Sony α6500 LCD Screen Replacement: step 10, image 1 of 2 Sony α6500 LCD Screen Replacement: step 10, image 2 of 2
      Tool used on this step:
      Buy
      • Carefully unplug the three wire ribbons from the circuit board with tweezers.
      • Likely you will need to wiggle the ribbons for a while before they come loose.
      • The ribbons can rip very easily, grasp the black plastic with the tweezers, on the two top ribbons, not the orange wires.
      Ask FixBot
    7. Sony α6500 LCD Screen Replacement: step 11, image 1 of 3 Sony α6500 LCD Screen Replacement: step 11, image 2 of 3 Sony α6500 LCD Screen Replacement: step 11, image 3 of 3
      • Slide the spudger around all sides of the screen's plastic frame, gently breaking the adhesive.
      • Remove the screen from the camera by prying it out.
      Ask FixBot
4 other people completed this guide.
Micah Fitzgerald
674 Reputation
2 Guides authored
Cal Poly, Team S11-G5, Regan Fall 2019 Member of Cal Poly, Team S11-G5, Regan Fall 2019
CPSU-REGAN-F19S11G5
5 Members
82 Guides authored
2 Guide Comments
Hello, do you have an updated link with a currently available lcd screen replacement part?
JRS - Joe’s Random Stuff - Reply Share
Can I use an a6500 screen to replace an a6600 screen? Are they interchangeable?
Connor Snyder - Reply Share
Past 24 Hours: 6
Past 7 Days: 17
Past 30 Days: 82
All Time: 4,972
