Sony α6000 Motherboard Replacement
  1. Sony α6000 Motherboard Replacement, Battery: step 1, image 1 of 2 Sony α6000 Motherboard Replacement, Battery: step 1, image 2 of 2
    • Begin by placing the camera facing upside down.
    Ask FixBot
  2. Sony α6000 Motherboard Replacement: step 2, image 1 of 2 Sony α6000 Motherboard Replacement: step 2, image 2 of 2
    • Slide the notched locking bar on the battery compartment from LOCK to OPEN.
    Ask FixBot
  3. Sony α6000 Motherboard Replacement: step 3, image 1 of 2 Sony α6000 Motherboard Replacement: step 3, image 2 of 2
    • Push the small blue bar horizontally off of the battery.
    Ask FixBot
  4. Sony α6000 Motherboard Replacement: step 4, image 1 of 2 Sony α6000 Motherboard Replacement: step 4, image 2 of 2
    • Remove the battery.
    Ask FixBot
  5. Sony α6000 Motherboard Replacement, Motherboard: step 5, image 1 of 1
    • Remove the 1.75mm Phillips #00 screw from the left side of the camera.
    Ask FixBot
  6. Sony α6000 Motherboard Replacement: step 6, image 1 of 2 Sony α6000 Motherboard Replacement: step 6, image 2 of 2
    • Remove the two 1.75mm Phillips #00 screws from inside the battery department.
    Ask FixBot
  7. Sony α6000 Motherboard Replacement: step 7, image 1 of 1
    • Remove the 1.75mm screw using a Phillips #00 head from underneath the flash.
    Ask FixBot
  8. Sony α6000 Motherboard Replacement: step 8, image 1 of 1
    Tool used on this step:
    Buy
    • Carefully remove the ribbon of the flash from the socket by using a pair of tweezers.
    • The best known method to removing the ribbon is to use a pair of tweezers with a rubber tip. This will help to prevent damage to the ribbon.
    Ask FixBot
  9. Sony α6000 Motherboard Replacement: step 9, image 1 of 1
    • The top of the camera will be free and can be removed.
    • Set the top of the camera to the side.
    Ask FixBot
  10. Sony α6000 Motherboard Replacement: step 10, image 1 of 1
    • Remove the three 1.75mm Phillips #00 screws just below the eye sensor.
    Ask FixBot
  11. Sony α6000 Motherboard Replacement: step 11, image 1 of 1
    • Remove the 1.75mm Phillips #00 screw from underneath the SD card cover.
    Ask FixBot
  12. Sony α6000 Motherboard Replacement: step 12, image 1 of 1
    • Remove two 1.75mm Phillips #00 screws from the bottom of the camera.
    Ask FixBot
  13. Sony α6000 Motherboard Replacement: step 13, image 1 of 1
    • Remove the 1.25mm screw from the right side underneath the battery cover.
    Ask FixBot
  14. Sony α6000 Motherboard Replacement: step 14, image 1 of 1
    • Remove the 1.75mm Phillips #00 screw just to the right of the eye sensor.
    Ask FixBot
  15. Sony α6000 Motherboard Replacement: step 15, image 1 of 1
    • Set the eye sensor aside.
    Ask FixBot
  16. Sony α6000 Motherboard Replacement: step 16, image 1 of 1
    • Remove the back panel of the camera.
    Ask FixBot
  17. Sony α6000 Motherboard Replacement: step 17, image 1 of 1
    • Remove the two 1.25mm Phillips #00 screws near the top of the camera, just to the left of the eye socket.
    Ask FixBot
  18. Sony α6000 Motherboard Replacement: step 18, image 1 of 1
    • Remove the two 1.75mm Phillips #00 screws from the bottom of the camera.
    Ask FixBot
  19. Sony α6000 Motherboard Replacement: step 19, image 1 of 1
    • Remove the three 1.75mm Phillips #00 screws from the right side of the camera.
    Ask FixBot
  20. Sony α6000 Motherboard Replacement: step 20, image 1 of 1
    • Remove one ribbon that is attached to the selector wheel with a pair of tweezers.
    Ask FixBot
  21. Sony α6000 Motherboard Replacement: step 21, image 1 of 1
    • lift up the protector plate and remove one ribbon that is attached to the LCD screen with a pair of tweezers.
    Ask FixBot
  22. Sony α6000 Motherboard Replacement: step 22, image 1 of 1
    • Detach the LCD screen from the back portion of the camera and set it aside.
    Ask FixBot
  23. Sony α6000 Motherboard Replacement: step 23, image 1 of 1
    • Lift up the black cover to reveal the motherboard and ten ribbons.
    • Use a pair of tweezers to gently pull the ribbon cables out of their sockets on the motherboard.
    Ask FixBot
  24. Sony α6000 Motherboard Replacement: step 24, image 1 of 1
    • Remove the four 1.25mm Phillips #00 screws located on the borders of the motherboard.
    Ask FixBot
  25. Sony α6000 Motherboard Replacement: step 25, image 1 of 1
    • Remove the power supply at the bottom right hand corner with a pair of tweezers.
    Ask FixBot
  26. Sony α6000 Motherboard Replacement: step 26, image 1 of 1
    • Lift the motherboard up and remove the last ribbon cable with a pair of tweezers.
    Ask FixBot
  27. Sony α6000 Motherboard Replacement: step 27, image 1 of 1
    • Remove the motherboard and set aside.
    Ask FixBot
3 other people completed this guide.
Rohn Albertson
635 Reputation
2 Guides authored
IUPUI, Team S2-G2, Harley Summer 2019 Member of IUPUI, Team S2-G2, Harley Summer 2019
IUPUI-HARLEY-SU19S2G2
3 Members
7 Guides authored
5 Guide Comments
I have been wondering what path I will take when I replace my battery contacts part and this looks like an ideal guide for how I can do it. I wondered why you don’t discharge the capacitor before removing ribbon cables. When I removed the top block off my nex-6 I did discharge the capacitor as what the service manual suggested before I removed the control dial and flash ribbon cables. Before I did it I found a youtube about using wires to the discharge contacts going to a light bulb to safely discharge the capacitor. The service manual suggests using a short jig R:1 k Ω/1 W but since I don’t have access to an electronics store nearby the youtube did the trick trouble free.
georgevp1 - Reply Share
I was successful with the dissembling the camera and will need to invest in a working logic board and maybe something that is part of the shutter. I was hoping the camera would be an easy fix but sometimes this isn’t this case.
is there a way to fix the hdmi out port without buying a new mother board?
Nicholas Costanza - Reply Share
Hi this is a really helpful guide thank you but I need to go a bit further to replace the sticky shutter. Do you have a guide for that please
richardmason18 - Reply Share
It really should be mentioned in step 9 to discharge the flash's capacitor using a resistor. It can be sitting at 200+ volts for long after the camera has been turned off, which is quite dangerous.
junstred - Reply Share
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 152
All Time: 6,453
