Sonos Roam Speaker Module Replacement
Views: 2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
71
All Time:
2,011
Comments: 5
5 comments on steps.
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
If your Sonos Roam is having audio issues such as distorted sound, cutting out, or no sound playing, then use this guide to replace the speaker module.
The speaker module is the large, internal component that produces the sound. A broken speaker module will result in various audio issues.
Before using this guide, make sure the Bluetooth is stable. Also try rebooting the device before performing any replacement.
There are steps that recommend (not require) the use of the iOpener. This will help with carefully removing the adhesive used to keep this device together. Refer to this link on how to properly use the iOpener.
Tools
    1. Sonos Roam Speaker Module Replacement, End Caps: step 1, image 1 of 3 Sonos Roam Speaker Module Replacement, End Caps: step 1, image 2 of 3 Sonos Roam Speaker Module Replacement, End Caps: step 1, image 3 of 3
      • Power off your Sonos Roam before beginning disassembly.
      • Use the metal spudger to pry the end cap with the buttons.
      • Pry from all sides to loosen the adhesive.
      • Use the iOpener, a blowdryer, or a similar heating device to loosen the adhesive if having difficulty.
      Ask FixBot
    2. Sonos Roam Speaker Module Replacement: step 2, image 1 of 2 Sonos Roam Speaker Module Replacement: step 2, image 2 of 2
      • Flip the device to the other end cap.
      • Use the metal spudger to loosen the adhesive.
      Ask FixBot
    1. Sonos Roam Speaker Module Replacement, Speaker Grille: step 3, image 1 of 2 Sonos Roam Speaker Module Replacement, Speaker Grille: step 3, image 2 of 2
      • Flip the device so that the Sonos logo is on the top.
      • Use the Torx T6 screwdriver to remove the two 6 mm screws.
      Ask FixBot
    2. Sonos Roam Speaker Module Replacement: step 4, image 1 of 2 Sonos Roam Speaker Module Replacement: step 4, image 2 of 2
      • Flip the device.
      Ask FixBot
    3. Sonos Roam Speaker Module Replacement: step 5, image 1 of 3 Sonos Roam Speaker Module Replacement: step 5, image 2 of 3 Sonos Roam Speaker Module Replacement: step 5, image 3 of 3
      • Flip the device so the Sonos logo is on the top.
      • Use the iFixit opening picks to wedge between the split of the grille and the back of the speaker to pry the grille apart.
      Ask FixBot
    1. Sonos Roam Speaker Module Replacement, Speaker Module: step 6, image 1 of 2 Sonos Roam Speaker Module Replacement, Speaker Module: step 6, image 2 of 2
      • Use the TR10 Torx screwdriver to remove the six 7 mm screws.
      Ask FixBot
    2. Sonos Roam Speaker Module Replacement: step 7, image 1 of 3 Sonos Roam Speaker Module Replacement: step 7, image 2 of 3 Sonos Roam Speaker Module Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Begin to carefully separate the speaker module from the device.
      • Firmly squeeze the middle of the plug using the tweezers to pull it out of the socket.
      • Separate the speaker module from the device.
      Ask FixBot
Lauren Young
899 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 71
All Time: 2,011
