Sonos Roam Inner Circuit Board Replacement
  1. Sonos Roam Inner Circuit Board Replacement, End Caps: step 1, image 1 of 3 Sonos Roam Inner Circuit Board Replacement, End Caps: step 1, image 2 of 3 Sonos Roam Inner Circuit Board Replacement, End Caps: step 1, image 3 of 3
    • Power off your Sonos Roam before beginning disassembly.
    • Use the metal spudger to pry the end cap with the buttons.
    • Pry from all sides to loosen the adhesive.
    • Use the iOpener, a blowdryer, or a similar heating device to loosen the adhesive if having difficulty.
  2. Sonos Roam Inner Circuit Board Replacement: step 2, image 1 of 2 Sonos Roam Inner Circuit Board Replacement: step 2, image 2 of 2
    • Flip the device to the other end cap.
    • Use the metal spudger to loosen the adhesive.
  3. Sonos Roam Inner Circuit Board Replacement, Speaker Grille: step 3, image 1 of 2 Sonos Roam Inner Circuit Board Replacement, Speaker Grille: step 3, image 2 of 2
    • Flip the device so that the Sonos logo is on the top.
    • Use the Torx T6 screwdriver to remove the two 6 mm screws.
  4. Sonos Roam Inner Circuit Board Replacement: step 4, image 1 of 2 Sonos Roam Inner Circuit Board Replacement: step 4, image 2 of 2
    • Flip the device.
  5. Sonos Roam Inner Circuit Board Replacement: step 5, image 1 of 3 Sonos Roam Inner Circuit Board Replacement: step 5, image 2 of 3 Sonos Roam Inner Circuit Board Replacement: step 5, image 3 of 3
    • Flip the device so the Sonos logo is on the top.
    • Use the iFixit opening picks to wedge between the split of the grille and the back of the speaker to pry the grille apart.
  6. Sonos Roam Inner Circuit Board Replacement, Speaker Module: step 6, image 1 of 2 Sonos Roam Inner Circuit Board Replacement, Speaker Module: step 6, image 2 of 2
    • Use the TR10 Torx screwdriver to remove the six 7 mm screws.
  7. Sonos Roam Inner Circuit Board Replacement: step 7, image 1 of 3 Sonos Roam Inner Circuit Board Replacement: step 7, image 2 of 3 Sonos Roam Inner Circuit Board Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Begin to carefully separate the speaker module from the device.
    • Firmly squeeze the middle of the plug using the tweezers to pull it out of the socket.
    • Separate the speaker module from the device.
  8. Sonos Roam Inner Circuit Board Replacement, Outer Circuit Board: step 8, image 1 of 2 Sonos Roam Inner Circuit Board Replacement, Outer Circuit Board: step 8, image 2 of 2
    • Use the TR10 Torx screwdriver to remove the four 7 mm screws.
  9. Sonos Roam Inner Circuit Board Replacement: step 9, image 1 of 3 Sonos Roam Inner Circuit Board Replacement: step 9, image 2 of 3 Sonos Roam Inner Circuit Board Replacement: step 9, image 3 of 3
    Buy
    • Use the tweezers to flip the latch holding the large ribbon in place.
    • Grab the large ribbon with the tweezers and pull upwards to remove it.
    • Use the tweezers to flip the latch holding the small ribbon in place.
    • Grab the small ribbon with the tweezers and pull upwards to remove it.
  10. Sonos Roam Inner Circuit Board Replacement: step 10, image 1 of 3 Sonos Roam Inner Circuit Board Replacement: step 10, image 2 of 3 Sonos Roam Inner Circuit Board Replacement: step 10, image 3 of 3
    • Grab the metal piece sticking out of the outer circuit board.
    • Pull upwards to remove the outer circuit board.
  11. Sonos Roam Inner Circuit Board Replacement: step 11, image 1 of 2 Sonos Roam Inner Circuit Board Replacement: step 11, image 2 of 2
    • Soldering Iron is very hot and can cause injury if not used properly.
    • Use a soldering iron to desolder the outer circuit board from the speaker casing.
  12. Sonos Roam Inner Circuit Board Replacement, Battery: step 12, image 1 of 2 Sonos Roam Inner Circuit Board Replacement, Battery: step 12, image 2 of 2
  13. Sonos Roam Inner Circuit Board Replacement: step 13, image 1 of 2 Sonos Roam Inner Circuit Board Replacement: step 13, image 2 of 2
    Buy
    • Use the tweezers to firmly squeeze the middle of the plug.
    • Pull the plug out to remove it from its socket.
    • Remove the battery from the device.
  14. Sonos Roam Inner Circuit Board Replacement: step 14, image 1 of 3 Sonos Roam Inner Circuit Board Replacement: step 14, image 2 of 3 Sonos Roam Inner Circuit Board Replacement: step 14, image 3 of 3
    • Use the iFixit opening tool to pry the battery out of its casing.
    • Use the iOpener, blowdryer, or a similar heating device to loosen the adhesive if having difficulty.
  15. Sonos Roam Inner Circuit Board Replacement: step 15, image 1 of 1
    • Remove the battery from its casing.
  16. Sonos Roam Inner Circuit Board Replacement, Inner Circuit Board: step 16, image 1 of 2 Sonos Roam Inner Circuit Board Replacement, Inner Circuit Board: step 16, image 2 of 2
    • Use the TR9 Torx screwdriver to remove the two 5 mm screws.
  17. Sonos Roam Inner Circuit Board Replacement: step 17, image 1 of 3 Sonos Roam Inner Circuit Board Replacement: step 17, image 2 of 3 Sonos Roam Inner Circuit Board Replacement: step 17, image 3 of 3
    Buy
    • Use the tweezers to firmly squeeze the center of the plug.
    • Grab the metal box to remove the inner circuit board.
Lauren Young
839 Reputation
5 Guides authored
3 Guide Comments
Danke für die Anleitung.
Ich müsste die Leiterplatte auch tauschen. Weiß jemand, wo es noch passenden Ersatz gibt?
Danyel Bürgel - Reply Share
Vielleicht hier?
VauWeh - Reply Share
Danke aber das hatte ich schon versucht. Bietet man nicht an. Ich kann den Fehler eingrenzen aber den Chip bekomme ich leider auch nirgends.
Past 24 Hours: 2
Past 7 Days: 30
Past 30 Days: 72
All Time: 997
