Tools
Introduction
Go to step 1 ↓If your Sonos Roam 2 speaker’s outer shell is cracked, dented, or otherwise damaged, use this guide to replace it.
The shell serves as the primary protective barrier for the internal components of the speaker. It absorbs impact from drops and bumps, shielding the delicate electronics inside.
Before starting this repair, inspect the shell for signs of structural damage that may affect performance. If the speaker still functions properly but the casing is compromised, replacing the shell can restore its durability and appearance.
Make sure to power off the speaker completely and disconnect it from any external power source before beginning.
Stand the speaker on either end so that it's vertical.
Wedge your opening pick between the speaker and the rubber triangle on the end of the speaker.
Wiggle the pick back and forth and drag the pick around the edges to break through this adhesive.
Completely remove the rubber triangle.
2 other people completed this guide.
