Sonos Roam 2 Battery Replacement
    1. Sonos Roam 2 Battery Replacement, Outer Shell: step 1, image 1 of 3 Sonos Roam 2 Battery Replacement, Outer Shell: step 1, image 2 of 3 Sonos Roam 2 Battery Replacement, Outer Shell: step 1, image 3 of 3
      • Stand the speaker on either end so that it's vertical.
      • Wedge your opening pick between the speaker and the rubber triangle on the end of the speaker.
      • There is a layer of adhesive you'll have to get through in order to take off the rubber end.
      • Wiggle the pick back and forth and drag the pick around the edges to break through this adhesive.
      • This may take a decent amount of time and effort as the adhesive can be a little stubborn.
      • Completely remove the rubber triangle.
      Ask FixBot
    2. Sonos Roam 2 Battery Replacement: step 2, image 1 of 2 Sonos Roam 2 Battery Replacement: step 2, image 2 of 2
      • Flip the speaker over and begin working on the rubber triangle on the other side.
      • Wedge your opening pick between the speaker and the rubber triangle. Wiggle the pick back and forth and drag the pick around the edges to break through the adhesive.
      • It may take a decent amount of time and effort to break through the adhesive.
      Ask FixBot
    3. Sonos Roam 2 Battery Replacement: step 3, image 1 of 2 Sonos Roam 2 Battery Replacement: step 3, image 2 of 2
      • Remove the two 7.5 mm screws using a T6 Torx screwdriver.
      • Flip the speaker over and remove the other two 7.5 mm screws using a T6 Torx screwdriver.
      Ask FixBot
    4. Sonos Roam 2 Battery Replacement: step 4, image 1 of 3 Sonos Roam 2 Battery Replacement: step 4, image 2 of 3 Sonos Roam 2 Battery Replacement: step 4, image 3 of 3
      • Insert your opening pick between the outer shell and the main body.
      • Work your way along the seam from top to bottom, gently prying at intervals to break the adhesive bond.
      • When the outer shell is adequately loosened, lift and remove the outer shell from the speaker assembly.
      Ask FixBot
    1. Sonos Roam 2 Battery Replacement, Speaker Driver: step 5, image 1 of 3 Sonos Roam 2 Battery Replacement, Speaker Driver: step 5, image 2 of 3 Sonos Roam 2 Battery Replacement, Speaker Driver: step 5, image 3 of 3
      • Remove the six 7.5 mm screws securing the speaker driver using a T10 Torx screwdriver.
      Ask FixBot
    2. Sonos Roam 2 Battery Replacement: step 6, image 1 of 2 Sonos Roam 2 Battery Replacement: step 6, image 2 of 2
      • Use the opening pick along the edge to gently lift and release the speaker driver.
      • Avoid excessive force when pulling, as this may damage the speaker.
      Ask FixBot
    3. Sonos Roam 2 Battery Replacement: step 7, image 1 of 2 Sonos Roam 2 Battery Replacement: step 7, image 2 of 2
      • Press the connector release tab and gently pull the speaker driver free, taking care not to strain the attached wires.
      Ask FixBot
    1. Sonos Roam 2 Battery Replacement, Battery: step 8, image 1 of 2 Sonos Roam 2 Battery Replacement, Battery: step 8, image 2 of 2
      • Remove the four 7.5 mm screws using a T10 Torx screwdriver.
      • One of the screws is hiding under the foam that's protecting a wire.
      Ask FixBot
    2. Sonos Roam 2 Battery Replacement: step 9, image 1 of 3 Sonos Roam 2 Battery Replacement: step 9, image 2 of 3 Sonos Roam 2 Battery Replacement: step 9, image 3 of 3
      • Use an opening pick to flip up the retaining flaps on each of the two connectors.
      • It doesn't take too much pressure to lift the flaps. You will not need to push very hard.
      Ask FixBot
    3. Sonos Roam 2 Battery Replacement: step 10, image 1 of 3 Sonos Roam 2 Battery Replacement: step 10, image 2 of 3 Sonos Roam 2 Battery Replacement: step 10, image 3 of 3
      • Use your opening pick and tweezers to pry out the black connector.
      • It may take a decent amount of pressure to pop these connectors out, but try to be careful and gentle.
      • Flip the speaker to better access the smaller black connector.
      • Use the opening pick to pry out the smaller black connector.
      Ask FixBot
    4. Sonos Roam 2 Battery Replacement: step 11, image 1 of 2 Sonos Roam 2 Battery Replacement: step 11, image 2 of 2
      • Pull the motherboard off of the battery case.
      • Do not try to pull the motherboard completely out of the speaker itself.
      Ask FixBot
    5. Sonos Roam 2 Battery Replacement: step 12, image 1 of 1
      • Remove the four 7.5 mm screws around the battery case using a T6 Torx screwdriver.
      Ask FixBot
    6. Sonos Roam 2 Battery Replacement: step 13, image 1 of 2 Sonos Roam 2 Battery Replacement: step 13, image 2 of 2
      • Use your thumb to pry out the battery case.
      • Do not pull on the case too hard as it is still connected via a wire.
      Ask FixBot
    7. Sonos Roam 2 Battery Replacement: step 14, image 1 of 3 Sonos Roam 2 Battery Replacement: step 14, image 2 of 3 Sonos Roam 2 Battery Replacement: step 14, image 3 of 3
      • Use a spudger to gently press on the connector pad.
      • Pull the battery case out of the speaker fully.
      Ask FixBot
    8. Sonos Roam 2 Battery Replacement: step 15, image 1 of 2 Sonos Roam 2 Battery Replacement: step 15, image 2 of 2
      • Use the Jimmy tool to pry out the battery and remove it completely from the case.
      • There is a layer of adhesive keeping the battery in its case. Prying out the battery may take a decent amount of effort.
      Ask FixBot
2 other people completed this guide.
Joseph Stewart
613 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 37
Past 30 Days: 163
All Time: 969
