Sonos Play 5 Audio/Control Board Replacement
    1. Sonos Play 5 Audio/Control Board Replacement, Front Panel Assembly: step 1, image 1 of 1
      • Disconnect any power to the speaker and wait a few minutes for the capacitors to fully discharge.
      • Flip the speaker upside down.
      • There may be a rubber foot covering the bottom screws (not included in picture). Remove this by pulling up from one of the corners using a spudger.
      Ask FixBot
    2. Sonos Play 5 Audio/Control Board Replacement: step 2, image 1 of 2 Sonos Play 5 Audio/Control Board Replacement: step 2, image 2 of 2
      • Remove eight 10mm Phillips #2 screws
      • Remove the bottom panel by pulling upwards.
      • Be very gentle with the ends of the three antennas. They are very fragile.
      Ask FixBot
    3. Sonos Play 5 Audio/Control Board Replacement: step 3, image 1 of 3 Sonos Play 5 Audio/Control Board Replacement: step 3, image 2 of 3 Sonos Play 5 Audio/Control Board Replacement: step 3, image 3 of 3
      • Flip the device so that the grille is facing up.
      • Locate the line on the right side of the speaker where the grill and the plastic meet, and place your plastic opening tool in the gap.
      • Run the spudger along the gap, loosening the grille from the plastic. Repeat this process on the left side as well.
      • Gently pull up on the grille, removing it from the front panel.
      Ask FixBot
    4. Sonos Play 5 Audio/Control Board Replacement: step 4, image 1 of 1
      • Remove the six 8mm Phillips #2 screws.
      • Remove the two 10mm Phillips #2 screws.
      Ask FixBot
    5. Sonos Play 5 Audio/Control Board Replacement: step 5, image 1 of 2 Sonos Play 5 Audio/Control Board Replacement: step 5, image 2 of 2
      • Locate the line on the right side where the front panel and back panel meet. Place a plastic opening tool in the gap, and run it along the gap. Repeat this on the left side.
      • Use the opening tool to lift the front plate. If a plastic tool is not providing enough leverage, use a metal opening tool.
      • Gently pull up on the face plate to ensure it has been detached from the enclosure.
      • When pulling on the face plate be cautious because it is still connected by wires on the back of the plate.
      Ask FixBot
    6. Sonos Play 5 Audio/Control Board Replacement: step 6, image 1 of 3 Sonos Play 5 Audio/Control Board Replacement: step 6, image 2 of 3 Sonos Play 5 Audio/Control Board Replacement: step 6, image 3 of 3
      • Lift up the front panel, forming a 90 degree angle with the back panel. Locate the locate ten pin connector shown. This is the wire that connects the front panel to back panel.
      • Press down on the small tab located on the connector. With the tab firmly pressed down, pull the connector out from its socket.
      • The faceplate assembly is now fully detached from the rest of the speaker.
      Ask FixBot
    1. Sonos Play 5 Audio/Control Board Replacement, Motherboard: step 7, image 1 of 3 Sonos Play 5 Audio/Control Board Replacement, Motherboard: step 7, image 2 of 3 Sonos Play 5 Audio/Control Board Replacement, Motherboard: step 7, image 3 of 3
      • Remove the ten pin connector.
      Ask FixBot
    2. Sonos Play 5 Audio/Control Board Replacement: step 8, image 1 of 1
      • Flip the device over on its front side.
      Ask FixBot
    3. Sonos Play 5 Audio/Control Board Replacement: step 9, image 1 of 1
      • Remove six 5mm Phillips #0 screws.
      • Remove two 7mm Phillips #2 screws.
      Ask FixBot
    4. Sonos Play 5 Audio/Control Board Replacement: step 10, image 1 of 1
      • Flip the device on its back.
      Ask FixBot
    5. Sonos Play 5 Audio/Control Board Replacement: step 11, image 1 of 3 Sonos Play 5 Audio/Control Board Replacement: step 11, image 2 of 3 Sonos Play 5 Audio/Control Board Replacement: step 11, image 3 of 3
      • Remove the grey and red antenna connectors by lifting them away from the board.
      • Pull cords away from the board.
      Ask FixBot
    6. Sonos Play 5 Audio/Control Board Replacement: step 12, image 1 of 2 Sonos Play 5 Audio/Control Board Replacement: step 12, image 2 of 2
      • Remove the yellow antenna connector by lifting it away from the board.
      • Pull cord away from the board.
      Ask FixBot
    7. Sonos Play 5 Audio/Control Board Replacement: step 13, image 1 of 3 Sonos Play 5 Audio/Control Board Replacement: step 13, image 2 of 3 Sonos Play 5 Audio/Control Board Replacement: step 13, image 3 of 3
      • Remove circuit board by lifting it straight away from the rear plate.
      Ask FixBot
    1. Sonos Play 5 Audio/Control Board Replacement, Audio/Control Board: step 14, image 1 of 1
      • Lay the two connected boards so that the power board is facing upwards
      Ask FixBot
    2. Sonos Play 5 Audio/Control Board Replacement: step 15, image 1 of 2 Sonos Play 5 Audio/Control Board Replacement: step 15, image 2 of 2
      • Unscrew Four Phillips #2 bolts
      • These bolts will not come out, but will pull out of the nuts on the other side of the board
      Ask FixBot
    3. Sonos Play 5 Audio/Control Board Replacement: step 16, image 1 of 1
      • Flip boards so audio board is facing upwards, as is shown in picture
      Ask FixBot
    4. Sonos Play 5 Audio/Control Board Replacement: step 17, image 1 of 3 Sonos Play 5 Audio/Control Board Replacement: step 17, image 2 of 3 Sonos Play 5 Audio/Control Board Replacement: step 17, image 3 of 3
      • Lift control board up and away from power supply board
      Ask FixBot
    5. Sonos Play 5 Audio/Control Board Replacement: step 18, image 1 of 1
      • The smaller of the two boards is the audio/control board.
      Ask FixBot
5 other people completed this guide.
Warren Willingham
1,179 Reputation
3 Guides authored
USF Tampa, Team S3-G6, Sullivan Spring 2017 Member of USF Tampa, Team S3-G6, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G6
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 53
All Time: 7,036
