Introduction
Go to step 1 ↓The wireless communication card receives sound through and internet connection. It is connected to three antenna throughout the speaker, which you will need to unplug from the card. This will need to be replaced if you are unable to wirelessly connect to the speaker.
Tools
Spudger4.9
Insert a spudger along the edge of the screen and gently use it to pull the screen away from the casing. Slide the spudger along the length of the grill to detach all the clips holding it in place.
Unscrew eight 1.5 inch Phillips #2 screws attaching the front speaker panel to the box.
Unscrew the single 1 inch Phillips #2 screw located on the left side of the panel. This may be hidden beneath the warranty void sticker that you'll want to remove.
Unscrew the single 3/4 inch Phillips #2 screw, which is the last thing holding the front panel to the casing.
Disconnect the motherboard from the power supply board by gently reaching in and pushing the tab underneath the wire connector and pulling towards you.
Using a Phillips screwdriver, unscrew the two screws securing the communication card to the motherboard.
4 other people completed this guide.
4 Guide Comments
Do you have a recommendation for a replacement wireless card? If so where can I purchase it?
This post really helped me reviving my Play:3 that suddenly stopped connecting to WIFI after more than 10 years of constant use. Just search on Becco's description and you will receive a 10 USD replacement piece installed within half an hour, instead of buying a new appliance for 40-times that amount. Always prefer mending over buying ;-)
