Sonos Play 1 Mid-Woofer speaker Replacement
    1. Sonos Play 1 Mid-Woofer speaker Replacement, Exterior Screen: step 1, image 1 of 2 Sonos Play 1 Mid-Woofer speaker Replacement, Exterior Screen: step 1, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the rubber footing from the bottom of the device. Pry it up from one end using one of the plastic opening tools.
      • Once you pry open one end, use precision tweezers to remove rubber footing.
      Ask FixBot
    2. Sonos Play 1 Mid-Woofer speaker Replacement: step 2, image 1 of 2 Sonos Play 1 Mid-Woofer speaker Replacement: step 2, image 2 of 2
      • Using a metal spudger, pry open a corner of the adhesive tape.
      • Use precision tweezers to remove the adhesive tape.
      Ask FixBot
    3. Sonos Play 1 Mid-Woofer speaker Replacement: step 3, image 1 of 2 Sonos Play 1 Mid-Woofer speaker Replacement: step 3, image 2 of 2
      • Remove the four 10 mm Torx security #10 screws that hold the base together.
      • Remove the base by lifting it vertically away from the bulk of the device.
      Ask FixBot
    4. Sonos Play 1 Mid-Woofer speaker Replacement: step 4, image 1 of 2 Sonos Play 1 Mid-Woofer speaker Replacement: step 4, image 2 of 2
      • Remove the 10 mm Torx security #10 screw that holds down the exterior screen.
      • Using precision tweezers, remove the metal bracket.
      Ask FixBot
    5. Sonos Play 1 Mid-Woofer speaker Replacement: step 5, image 1 of 1
      • Remove the exterior screen by lifting it away from the bulk of the device.
      Ask FixBot
    1. Sonos Play 1 Mid-Woofer speaker Replacement, Sonos Play 1 Top Cover Disassembly: step 6, image 1 of 1
      • Remove the four 9 mm Torx Security #9 head screws. There are two on each side.
      Ask FixBot
    2. Sonos Play 1 Mid-Woofer speaker Replacement: step 7, image 1 of 3 Sonos Play 1 Mid-Woofer speaker Replacement: step 7, image 2 of 3 Sonos Play 1 Mid-Woofer speaker Replacement: step 7, image 3 of 3
      • Using a plastic opening tool, pry open the top cap containing the power and volume button.
      • Vertically remove the top cap.
      • Be sure to not jerk the top cap when removing , as to not damage the cable linking the switchboard to the motherboard.
      Ask FixBot
    3. Sonos Play 1 Mid-Woofer speaker Replacement: step 8, image 1 of 2 Sonos Play 1 Mid-Woofer speaker Replacement: step 8, image 2 of 2
      • Using a plastic opening tool, pry open the circuit flap.
      • Once flap is loosened, use your hand to remove the circuit wire.
      Ask FixBot
    1. Sonos Play 1 Mid-Woofer speaker Replacement, Disassembling Sonos Play 1 Rear Housing Cover: step 9, image 1 of 2 Sonos Play 1 Mid-Woofer speaker Replacement, Disassembling Sonos Play 1 Rear Housing Cover: step 9, image 2 of 2
      • Using a plastic opening tool, remove the grey tape from both sides of the device.
      Ask FixBot
    2. Sonos Play 1 Mid-Woofer speaker Replacement: step 10, image 1 of 2 Sonos Play 1 Mid-Woofer speaker Replacement: step 10, image 2 of 2
      • Remove the six 9 mm Torx #9 screws.
      • Using a plastic opening tool, detach the rear housing cover from the housing.
      • Try not to jerk the rear housing cover, as its wires are still connected to delicate electronics.
      Ask FixBot
    3. Sonos Play 1 Mid-Woofer speaker Replacement: step 11, image 1 of 2 Sonos Play 1 Mid-Woofer speaker Replacement: step 11, image 2 of 2
      Buy
      • Using tweezers, grip the connector fixed to the motherboard's audio cable.
      • While pulling on the connector, detach the cable by pressing the connectors release.
      Ask FixBot
    4. Sonos Play 1 Mid-Woofer speaker Replacement: step 12, image 1 of 1
      • Using your fingers, grip the connector fixed to the motherboards power cable and detach it.
      • You will now be able to remove the rear housing cover.
      Ask FixBot
    1. Sonos Play 1 Mid-Woofer speaker Replacement, Mid-Woofer speaker: step 13, image 1 of 1
      • Remove the two 9mm Torx #9 screws fastening the power cable to the housing.
      • Remove the power cable.
      Ask FixBot
    2. Sonos Play 1 Mid-Woofer speaker Replacement: step 14, image 1 of 1
      • Using a metal spudger, press the release located in the center of the connector .
      • While pressing the release pull on the connector detaching it from the speaker.
      • Do this for both connections.
      Ask FixBot
    3. Sonos Play 1 Mid-Woofer speaker Replacement: step 15, image 1 of 2 Sonos Play 1 Mid-Woofer speaker Replacement: step 15, image 2 of 2
      • Using the Torx T20 bit remove the four 13 mm screws fastening the speaker to the housing.
      • Remove the speaker by lifting it up towards the top of the housing and out at an angle.
      Ask FixBot
18 other people completed this guide.
Gregory Klein
737 Reputation
2 Guides authored
USF Tampa, Team 8-4, Eyestone Fall 2015 Member of USF Tampa, Team 8-4, Eyestone Fall 2015
USFT-EYESTONE-F15S8G4
4 Members
23 Guides authored
44 Guide Comments
Step 12 omits the connection to the Wi-Fi board. It's attached behind the hand in the picture and removing two T7 screws lets it slide out.
Maurice Leacock - Reply Share
Where can i buy a new mid-woofer speaker?
Krister Skaathun - Reply Share
Hi you have notice for midWoofer? asmaccocell@gmail.com
asmacco - Reply Share
Nice guide. But without a matching replacement speaker, or at least specifications, it is useless. Even worse: without opening my Play:1 would be accepted at Sonos support :(
Bebblebrox99 - Reply Share
true true ))
totally pointless
whats the specs to replace the subwoofer
montpc74 - Reply Share
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 161
All Time: 42,640
