Sonos Play 1 Exterior Screen Replacement
  1. Sonos Play 1 Exterior Screen Replacement, Exterior Screen: step 1, image 1 of 2 Sonos Play 1 Exterior Screen Replacement, Exterior Screen: step 1, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the rubber footing from the bottom of the device. Pry it up from one end using one of the plastic opening tools.
    • Once you pry open one end, use precision tweezers to remove rubber footing.
  2. Sonos Play 1 Exterior Screen Replacement: step 2, image 1 of 2 Sonos Play 1 Exterior Screen Replacement: step 2, image 2 of 2
    • Using a metal spudger, pry open a corner of the adhesive tape.
    • Use precision tweezers to remove the adhesive tape.
  3. Sonos Play 1 Exterior Screen Replacement: step 3, image 1 of 2 Sonos Play 1 Exterior Screen Replacement: step 3, image 2 of 2
    • Remove the four 10 mm Torx security #10 screws that hold the base together.
    • Remove the base by lifting it vertically away from the bulk of the device.
  4. Sonos Play 1 Exterior Screen Replacement: step 4, image 1 of 2 Sonos Play 1 Exterior Screen Replacement: step 4, image 2 of 2
    • Remove the 10 mm Torx security #10 screw that holds down the exterior screen.
    • Using precision tweezers, remove the metal bracket.
  5. Sonos Play 1 Exterior Screen Replacement: step 5, image 1 of 1
    • Remove the exterior screen by lifting it away from the bulk of the device.
16 other people completed this guide.
Adan Camerino Macias
561 Reputation
3 Guides authored
USF Tampa, Team 8-4, Eyestone Fall 2015 Member of USF Tampa, Team 8-4, Eyestone Fall 2015
USFT-EYESTONE-F15S8G4
4 Members
16 Guides authored
7 Guide Comments
Where can you purchase a replacement screen please? I dented mine by accident.
Imran Behlim - Reply Share
I have the same question, where can i buy a replacement screen?
Bosyd - Reply Share
I have the same question,. Where can I buy a replacement screen?
Bosyd - Reply Share
worked great, with dents both peened out no metal stretch, can’t tell was ever damaged A+ info thanks. George
pogocat69 - Reply Share
Great tip, used your advise and repainted due to missing paint on dents and it looks new!
R RYAN - Reply Share
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 142
All Time: 19,420
