Sonos One Tweeter Diaphragm Repair/ Replacement
  1. Sonos One Tweeter Diaphragm Repair/ Replacement, Protective Cover: step 1, image 1 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement, Protective Cover: step 1, image 2 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement, Protective Cover: step 1, image 3 of 3
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
    • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
    Ask FixBot
  2. Sonos One Tweeter Diaphragm Repair/ Replacement: step 2, image 1 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement: step 2, image 2 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement: step 2, image 3 of 3
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
    Ask FixBot
  3. Sonos One Tweeter Diaphragm Repair/ Replacement: step 3, image 1 of 2 Sonos One Tweeter Diaphragm Repair/ Replacement: step 3, image 2 of 2
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
    Ask FixBot
  4. Sonos One Tweeter Diaphragm Repair/ Replacement: step 4, image 1 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement: step 4, image 2 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement: step 4, image 3 of 3
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
    Ask FixBot
  5. Sonos One Tweeter Diaphragm Repair/ Replacement: step 5, image 1 of 2 Sonos One Tweeter Diaphragm Repair/ Replacement: step 5, image 2 of 2
    • Slide the protective cover upwards to remove.
    Ask FixBot
  6. Sonos One Tweeter Diaphragm Repair/ Replacement, Control Panel & Microphone: step 6, image 1 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement, Control Panel & Microphone: step 6, image 2 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement, Control Panel & Microphone: step 6, image 3 of 3
    • Use the pointed end of a spudger to remove the covers that hide the screws.
    • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
    Ask FixBot
  7. Sonos One Tweeter Diaphragm Repair/ Replacement: step 7, image 1 of 2 Sonos One Tweeter Diaphragm Repair/ Replacement: step 7, image 2 of 2
    • With the front of the unit facing you, lift the control panel up using your thumbs.
    • There's a ribbon cable attaching the control panel to the speaker so work slowly.
    Ask FixBot
  8. Sonos One Tweeter Diaphragm Repair/ Replacement: step 8, image 1 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement: step 8, image 2 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement: step 8, image 3 of 3
    • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
    • Pull the control panel ribbon cable out of its socket.
    Ask FixBot
  9. Sonos One Tweeter Diaphragm Repair/ Replacement: step 9, image 1 of 2 Sonos One Tweeter Diaphragm Repair/ Replacement: step 9, image 2 of 2
    • Pull the control panel away from the speaker to separate.
    Ask FixBot
  10. Sonos One Tweeter Diaphragm Repair/ Replacement, Power Adapter Receptacle: step 10, image 1 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement, Power Adapter Receptacle: step 10, image 2 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement, Power Adapter Receptacle: step 10, image 3 of 3
    • Remove the six 9mm Torx T8 screws from the motherboard panel.
    Ask FixBot
  11. Sonos One Tweeter Diaphragm Repair/ Replacement: step 11, image 1 of 2 Sonos One Tweeter Diaphragm Repair/ Replacement: step 11, image 2 of 2
    • Using a plastic opening tool, separate the motherboard from the speaker.
    Ask FixBot
  12. Sonos One Tweeter Diaphragm Repair/ Replacement: step 12, image 1 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement: step 12, image 2 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement: step 12, image 3 of 3
    • Using your thumb, disconnect the speaker cable from the motherboard.
    Ask FixBot
  13. Sonos One Tweeter Diaphragm Repair/ Replacement: step 13, image 1 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement: step 13, image 2 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement: step 13, image 3 of 3
    • Disconnect the power adapter plug from the motherboard using your thumb.
    Ask FixBot
  14. Sonos One Tweeter Diaphragm Repair/ Replacement: step 14, image 1 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement: step 14, image 2 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement: step 14, image 3 of 3
    • Using the pointed end of the spudger, disconnect the red, green, and yellow cables connecting the WiFi transmitter/receiver.
    Ask FixBot
  15. Sonos One Tweeter Diaphragm Repair/ Replacement: step 15, image 1 of 2 Sonos One Tweeter Diaphragm Repair/ Replacement: step 15, image 2 of 2
    • Remove the motherboard panel from the speaker housing.
    Ask FixBot
  16. Sonos One Tweeter Diaphragm Repair/ Replacement: step 16, image 1 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement: step 16, image 2 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement: step 16, image 3 of 3
    • The woofer is highly magnetic, making removal of the metal screws sometimes difficult.
    • Remove the two 9mm Torx T8 screws from the power adapter plug.
    • Remove the power adapter receptacle from its housing slot.
    Ask FixBot
  17. Sonos One Tweeter Diaphragm Repair/ Replacement, Tweeter Diaphragm: step 17, image 1 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement, Tweeter Diaphragm: step 17, image 2 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement, Tweeter Diaphragm: step 17, image 3 of 3
    • Disconnect the woofer cables.
    • If removing the tabs is difficult, the flat end of the spudger may be used to depress the middle tab and then the tab may be pulled to disconnect.
    Ask FixBot
  18. Sonos One Tweeter Diaphragm Repair/ Replacement: step 18, image 1 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement: step 18, image 2 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement: step 18, image 3 of 3
    • Disconnect the cables from the tweeter.
    Ask FixBot
  19. Sonos One Tweeter Diaphragm Repair/ Replacement: step 19, image 1 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement: step 19, image 2 of 3 Sonos One Tweeter Diaphragm Repair/ Replacement: step 19, image 3 of 3
    • Remove the four 10mm Torx T10 screws from the tweeter.
    • Remove the tweeter from the speaker housing.
    Ask FixBot
2 other people completed this guide.
Marcus Glowa
1,134 Reputation
5 Guides authored
USF Tampa, Team S2-G1, Nance Spring 2018 Member of USF Tampa, Team S2-G1, Nance Spring 2018
USFT-NANCE-S18S2G1
3 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 47
All Time: 3,884
