Up to 20% off select tools
Sonos One Protective Cover Replacement
Views: 8.5K
View statistics:
Past 24 Hours:
25
Past 7 Days:
99
Past 30 Days:
271
All Time:
8,530
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
This guide is for the replacement of the metal housing for the Sonos One.
Important: Accessing the internals of the Sonos One will void the factory warranty and make the unit rejected for factory repair, even if warranty is expired.
    1. Sonos One Protective Cover Replacement, Protective Cover: step 1, image 1 of 3 Sonos One Protective Cover Replacement, Protective Cover: step 1, image 2 of 3 Sonos One Protective Cover Replacement, Protective Cover: step 1, image 3 of 3
      • Disconnect all power cords.
      • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
      • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
      Ask FixBot
    2. Sonos One Protective Cover Replacement: step 2, image 1 of 3 Sonos One Protective Cover Replacement: step 2, image 2 of 3 Sonos One Protective Cover Replacement: step 2, image 3 of 3
      • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
      Ask FixBot
    3. Sonos One Protective Cover Replacement: step 3, image 1 of 2 Sonos One Protective Cover Replacement: step 3, image 2 of 2
      • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
      Ask FixBot
    4. Sonos One Protective Cover Replacement: step 4, image 1 of 3 Sonos One Protective Cover Replacement: step 4, image 2 of 3 Sonos One Protective Cover Replacement: step 4, image 3 of 3
      • The protective cover clip is very thin and deforms easily.
      • Remove the single 8mm Torx T10 screw and protective cover clip.
      Ask FixBot
    5. Sonos One Protective Cover Replacement: step 5, image 1 of 2 Sonos One Protective Cover Replacement: step 5, image 2 of 2
      • Slide the protective cover upwards to remove.
      Ask FixBot
4 other people completed this guide.
Author
with
Marcus Glowa
1,134 Reputation
5 Guides authored
USF Tampa, Team S2-G1, Nance Spring 2018 Member of USF Tampa, Team S2-G1, Nance Spring 2018
USFT-NANCE-S18S2G1
3 Members
60 Guides authored
2 Guide Comments
Well done! I would add a little bit about how much adhesive there is underneath the rubber feet as well as the screw cover.
Joshua Pinter - Reply Share
Thanks for the helpful instructions! Could you let me know where I can order the protective case?
Nick Geleedst - Reply Share
Past 24 Hours: 25
Past 7 Days: 99
Past 30 Days: 271
All Time: 8,530
