Introduction
Is your Sonos Era 100 not producing sound or have a distorted bass sound? This guide will walk you through the process of replacing the woofer. You will start with successfully dissembling the speaker to reach the inside components. After, you will use tools such as, tweezers, a metal spudger, and a screwdriver to replace the woofer.
Gently pull off the rubber foot on the the bottom of the speaker.
Remove the five 11 mm Torx T20 screws that secure the bottom plate.
Carefully lift off the bottom plate.
Remove all four T10 Torx screws securing the touch bar assembly.
Use an opening tool to release all four white retaining clips.
Lift the touch bar assembly perpendicular to the unit, with care not to strain the connected ribbon cable.
Lift the black ZIF locking flap that secures the touch bar assembly ribbon cable.
Disconnect the ribbon cable.
Remove the touch bar assembly.
Use tweezers to disconnect the positive and negative wires from the back of the woofer.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
