Sonos Era 100 Outer Casing Disassembly
  1. Sonos Era 100 Outer Casing Disassembly, Outer Casing: step 1, image 1 of 3 Sonos Era 100 Outer Casing Disassembly, Outer Casing: step 1, image 2 of 3 Sonos Era 100 Outer Casing Disassembly, Outer Casing: step 1, image 3 of 3
    • Gently pull off the rubber foot on the the bottom of the speaker.
    • Take care not to stretch or damage the rubber foot if you intend to reuse it. Use a hairdryer or iOpener to lightly heat the foot adhesive to aid in removal.
    • Remove the five 11 mm Torx T20 screws that secure the bottom plate.
    • Carefully lift off the bottom plate.
    Ask FixBot
  2. Sonos Era 100 Outer Casing Disassembly: step 2, image 1 of 3 Sonos Era 100 Outer Casing Disassembly: step 2, image 2 of 3 Sonos Era 100 Outer Casing Disassembly: step 2, image 3 of 3
    • Carefully disconnect the ribbon cable connected underneath the bottom panel.
    • To detach the back panel, gently push it in a downward motion.
    • Be especially mindful of the delicate ribbon cable attached to the top edge.
    • Use tweezers to disconnect the USB-C PCB from the back panel.
    Ask FixBot
  3. Sonos Era 100 Outer Casing Disassembly: step 3, image 1 of 3 Sonos Era 100 Outer Casing Disassembly: step 3, image 2 of 3 Sonos Era 100 Outer Casing Disassembly: step 3, image 3 of 3
    • Remove the 8 mm and 11 mm T10 Torx screws securing the speaker grille.
    • Once removed, the speaker grill should fall to both sides of the speaker.
    Ask FixBot
  4. Sonos Era 100 Outer Casing Disassembly: step 4, image 1 of 2 Sonos Era 100 Outer Casing Disassembly: step 4, image 2 of 2
    • Using a halberd spudger, carefully remove the foam tape. Do this by keeping tension on the foam shown in the images and slicing underneath the tape.
    • Pull the speaker grille off.
    Ask FixBot
  5. Sonos Era 100 Outer Casing Disassembly: step 5, image 1 of 3 Sonos Era 100 Outer Casing Disassembly: step 5, image 2 of 3 Sonos Era 100 Outer Casing Disassembly: step 5, image 3 of 3
    • Remove all four T10 Torx screws securing the touch bar assembly.
    • Use an opening tool to release all four white retaining clips.
    • Lift the touch bar assembly perpendicular to the unit, with care not to strain the connected ribbon cable.
    • Lift the black ZIF locking flap that secures the touch bar assembly ribbon cable.
    • Disconnect the ribbon cable.
    • Remove the touch bar assembly.
    Ask FixBot
Nick F.
587 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 59
All Time: 609
