Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓If the troubleshooting guide for the WIFI problems hasn't fixed your issue, this guide is for replacing the WIFI card in your Sonos Connect.
Tools
Spudger4.9
Start by using a spudger or plastic opening tool to remove the bottom cover.
Once enough of the glue is removed, peel the cover off by hand,
4 Guide Comments
great piece of advice. After some searching I found this on ebay.
https://www.ebay.co.uk/itm/Atheros-AR500...
or type in search bar Atheros AR5008 AR5416 Mini PCI N 802.11N 300M WIFI Wireless Card Dell ASUS SONY.
It cost me around £10.00 and seems to be working fine now after installation
Do you know the wireless card for the sonos connect s15?
I successfully replaced the faulty WiFi card in my SONOS Connect Model S15 with an
Apple AirPort Extreme Atheros AR5BXB112 / AR9380 / 250-01927-050 / 607-7212-A card.
Bought used on eBay for under €10.
The original card caused a red flashing light on boot most of the time.
With the card removed, the unit booted stably over Ethernet, but factory reset failed when the original card was installed.
Running Sonos OS S2, version 17.2.5 (Build 86.7-77050).
Factory reset and update both worked normally after replacement.
