This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Sonos Connect Fuse Replacement
    1. Sonos Connect Fuse Replacement, Bottom Part: step 1, image 1 of 1
      • Remove the rubber pads and unscrew
      Ask FixBot
    2. Sonos Connect Fuse Replacement, Continue to unscrew: step 2, image 1 of 1
      • Take care not to damage the wires of the Wi-Fi antennas which are very bothersome.
      Ask FixBot
    3. Sonos Connect Fuse Replacement, Unclip the top cover: step 3, image 1 of 2 Sonos Connect Fuse Replacement, Unclip the top cover: step 3, image 2 of 2
      • By using a screwdriver inserted through each of the 8 peripheral slots, you can access the clips of the top cover.
      Ask FixBot
    4. Sonos Connect Fuse Replacement, Access under the top cover: step 4, image 1 of 1
      • Continue unscrewing (there is a screw under the seal).
      Ask FixBot
    5. Sonos Connect Fuse Replacement, Locate the fuse: step 5, image 1 of 1
      • It's a soldered fuse. You will need to desolder it from the back in order to replace it.
      Ask FixBot
    6. Sonos Connect Fuse Replacement, Replacement fuse: step 6, image 1 of 1
      • About 1$
      • 250V 5A T fuse (time delay).
      Ask FixBot
Special thanks to these translators:
fr en
56%
These translators are helping us fix the world! Want to contribute?
Start translating ›
YvesG
290 Reputation
2 Guides authored
1 Guide Comment
Bravo
Ce tuto peux rendre service a des consommateurs abusés par la sociète Sonos .
Merci
bruno vinay - Reply Share
Past 24 Hours: 0
Past 7 Days: 24
Past 30 Days: 76
All Time: 4,067
