Sonos Bridge Power Port Replacement
    1. Sonos Bridge Power Port Replacement, Power Port: step 1, image 1 of 1
      • The rubber bottom is glued on, meaning it can be easily pried off using the metal spudger.
      • You may have to pry from multiple locations.
      Ask FixBot
    2. Sonos Bridge Power Port Replacement: step 2, image 1 of 3 Sonos Bridge Power Port Replacement: step 2, image 2 of 3 Sonos Bridge Power Port Replacement: step 2, image 3 of 3
      • There is one screw in each corner of the base for a total of four screws.
      • Remove each screw using the Phillips 1 screwdriver.
      • The four screws are each 0.9 cm long.
      • The screws are small, so be careful to not lose them.
      Ask FixBot
    3. Sonos Bridge Power Port Replacement: step 3, image 1 of 2 Sonos Bridge Power Port Replacement: step 3, image 2 of 2
      • Use the metal spudger to pry out the plastic bottom.
      • Alternatively, the casing can be lightly tapped on a table (base down) to drop the bottom out of the casing.
      Ask FixBot
    4. Sonos Bridge Power Port Replacement: step 4, image 1 of 2 Sonos Bridge Power Port Replacement: step 4, image 2 of 2
      • Pry out the circuit board.
      • Place the metal spudger under the board on the side opposite the two ports.
      • The board can then be easily wiggled out of the casing.
      • This should NOT require significant force.
      Ask FixBot
    5. Sonos Bridge Power Port Replacement: step 5, image 1 of 2 Sonos Bridge Power Port Replacement: step 5, image 2 of 2
      • Locate the Power port on the circuit board, shown with the red box in the first image.
      • Locate the solders attached to the Power port.
      • Use the soldering iron to undo the solders.
      Ask FixBot
Brian Strader
201 Reputation
2 Guides authored
IUPUI, Team S3-G4, Harley Fall 2017 Member of IUPUI, Team S3-G4, Harley Fall 2017
IUPUI-HARLEY-F17S3G4
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 22
All Time: 1,693
