Up to 20% off select tools
Solio Rocsta Charging Cable Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
85
All Time:
767
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 25 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
The Solio Rocsta's charging cable is the main connection for charging/using your device. In this guide, we will show you how to replace your charging cable if it no longer works or needs repairing.
Please note that this guide requires soldering. For more information on how to solder and desolder connections, please visit this guide.
    1. Solio Rocsta Charging Cable Replacement, Charging Cable: step 1, image 1 of 2 Solio Rocsta Charging Cable Replacement, Charging Cable: step 1, image 2 of 2
      • Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
      Ask FixBot
    2. Solio Rocsta Charging Cable Replacement: step 2, image 1 of 2 Solio Rocsta Charging Cable Replacement: step 2, image 2 of 2
      • Remove top cover.
      • Caution: the solar cell is attached to the top cover and connected to the circuit board by a short wire.
      Ask FixBot
    3. Solio Rocsta Charging Cable Replacement: step 3, image 1 of 1
      • Using the spudger, pry the battery off the back cover.
      Ask FixBot
    4. Solio Rocsta Charging Cable Replacement: step 4, image 1 of 1
      • Unscrew the 5.66 mm screws attaching the circuit board to the case.
      Ask FixBot
    5. Solio Rocsta Charging Cable Replacement: step 5, image 1 of 1
      • With the circuit board flipped, locate the battery connector.
      • Hold the component attached to the circuit board the battery is connected to and wiggle the cable out.
      Ask FixBot
    6. Solio Rocsta Charging Cable Replacement: step 6, image 1 of 1
      • With a Soldering Iron, desolder the four cables that connect the charging cable to the circuit board.
      • The power cable is a series of four cables. Make note of each cable placement for easy resoldering.
      • For more information on how to solder and desolder connections, please visit this guide.
      Ask FixBot
Author
with
David Vazquez
577 Reputation
5 Guides authored
USF Tampa, Team S13-G13, Cagle Fall 2017 Member of USF Tampa, Team S13-G13, Cagle Fall 2017
USFT-CAGLE-F17S13G13
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 85
All Time: 767
