Up to 20% off select tools
Solio Bolt Battery Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
93
All Time:
958
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Solio Bolt Battery Replacement, Remove Screw: step 1, image 1 of 1
      • Open the solar panel of the Solio Bolt. Using a philips screwdriver, remove the screw.
      Ask FixBot
    2. Solio Bolt Battery Replacement, Open Case: step 2, image 1 of 1
      • Use a plastic spudger to pry apart the case.
      Ask FixBot
    3. Solio Bolt Battery Replacement, Remove The 'Battery Holder' Assembly: step 3, image 1 of 2 Solio Bolt Battery Replacement, Remove The 'Battery Holder' Assembly: step 3, image 2 of 2
      • Use a philips screwdriver to remove the three screws securing the battery cradle to the device case.
      Ask FixBot
    1. Solio Bolt Battery Replacement, Free Motherboard: step 4, image 1 of 2 Solio Bolt Battery Replacement, Free Motherboard: step 4, image 2 of 2
      • Move the battery slightly, the motherboard can now be lifted from the device case.
      Ask FixBot
    2. Solio Bolt Battery Replacement, Discconnect Battery: step 5, image 1 of 1
      • On the underside of the motherboard, remove the battery lead from its connecting terminal.
      Ask FixBot
Author
with
Ethel
324 Reputation
3 Guides authored
UMass Dartmouth, Team 1-3, Shastany Fall 2014 Member of UMass Dartmouth, Team 1-3, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G3
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 93
All Time: 958
