Sol Republic Punk Battery Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
58
All Time:
1,070
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Here is a Sol Republic Punk Bluetooth speaker that no longer holds a charge. Not sure why a 9 year old battery would just quit charging :-) Actually, this speaker according to their owner, has been doing really well and it is actually well cared for. It is in good shape for its year and was even kept in the original box.
It is easily taken apart and does not require great dexterity or special tools.
Parts
Tools
    1. Sol Republic Punk Battery Replacement, Battery: step 1, image 1 of 3 Sol Republic Punk Battery Replacement, Battery: step 1, image 2 of 3 Sol Republic Punk Battery Replacement, Battery: step 1, image 3 of 3
      • Sol Republic Punk in its original box. Nice to see.
      • It still has the original instructions as well.
      • Turn the Punk over
      Ask FixBot
    2. Sol Republic Punk Battery Replacement: step 2, image 1 of 3 Sol Republic Punk Battery Replacement: step 2, image 2 of 3 Sol Republic Punk Battery Replacement: step 2, image 3 of 3
      • First thing to do is to loosen the rubber gasket which protects the Punk from Dust and moisture (to a certain degree). Use a spudger or similar tool for that
      • and move it all the way along between the Punk housing and the gasket
      • Once the gasket is loose and there is no adhesive holding it to the Punk housing, simply start pulling it over on the Punk housing.
      • The gasket will not yet come off. It is still attached to the Punk housing by the front grill.
      Ask FixBot
    3. Sol Republic Punk Battery Replacement: step 3, image 1 of 3 Sol Republic Punk Battery Replacement: step 3, image 2 of 3 Sol Republic Punk Battery Replacement: step 3, image 3 of 3
      • The rubber gasket has now been fully inverted and is only attached by the speaker grill to the front of the Punk housing
      • The speaker grill is attached via four (4) locking tabs in the housing. There are four relief openings. One on each corner of the housing.
      • Use a spudger or similar tool and insert it into the opening. A little inward push with the spudger will release the grill.
      • Once all four tabs have been released, the grill and rubber gasket will simply come off.
      Ask FixBot
    4. Sol Republic Punk Battery Replacement: step 4, image 1 of 3 Sol Republic Punk Battery Replacement: step 4, image 2 of 3 Sol Republic Punk Battery Replacement: step 4, image 3 of 3
      • This shows how the Grill secures the rubber gasket. the locking tab from the grill fits through the opening in the gasket and then the Punk housing.
      • Front grill and gasket removed and now the slots for the locking tabs for the grill are fully visible
      • With the gasket and the grill removed, use an opening tool (i.e.guitar pick) and insert it between the halves of the Punk housing. There is some glue between the case halves, so a bit of pressure and wiggling maybe needed.
      Ask FixBot
    5. Sol Republic Punk Battery Replacement: step 5, image 1 of 3 Sol Republic Punk Battery Replacement: step 5, image 2 of 3 Sol Republic Punk Battery Replacement: step 5, image 3 of 3
      • Ensure that the opening tool is just marginal larger than the split line. The smaller it is the easier it is to use
      • Move the opening tool all along the split line around the Punk housing
      • The Top and bottom half will separate once all the adhesive has been loosened by the opening tool
      Ask FixBot
    6. Sol Republic Punk Battery Replacement: step 6, image 1 of 3 Sol Republic Punk Battery Replacement: step 6, image 2 of 3 Sol Republic Punk Battery Replacement: step 6, image 3 of 3
      • The battery is a 18490 Li_ion 5.18Wh 1400mAh 3.7V
      • Now simply unsolder the battery leads
      • and remove the battery for replacement.
      Ask FixBot
    7. Sol Republic Punk Battery Replacement: step 7, image 1 of 1
      • Here is the battery with the protective cover removed. The battery control board is clearly visible and will have to be transferred to a replacement battery, unless one can find a genuine Punk replacement.
      Ask FixBot
oldturkey03
863,002 Reputation
123 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
43 Members
7,058 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 58
All Time: 1,070
