Sol Republic Deck Speaker Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
84
All Time:
2,755
Comments: 4
4 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Difficult
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Introduction
Go to step 1 ↓
This guide will teach you how to replace the speakers for the Sol Republic Deck.
Tools
    1. Sol Republic Deck Speaker Replacement, Speaker: step 1, image 1 of 1
      • With plastic spudger wedge in between the top and bottom casings to force sepearation . Exposing the inside components of the Republic Deck.
      Ask FixBot
    2. Sol Republic Deck Speaker Replacement: step 2, image 1 of 1
      • Use the screwdriver to unscrew 2 3.63mm Phillips #0 screws securing the plastic plate.
      Ask FixBot
    3. Sol Republic Deck Speaker Replacement: step 3, image 1 of 1
      • Unplug the ribbon cable from the port.
      Ask FixBot
    4. Sol Republic Deck Speaker Replacement: step 4, image 1 of 1
      • Unscrew 5 3.63 mm Phillips #0 screws securing the circuit board.
      Ask FixBot
    5. Sol Republic Deck Speaker Replacement: step 5, image 1 of 1
      • Unscrew 15 6.15 mm Phillips #0 screws and lift the black plastic plate from the case.
      Ask FixBot
    6. Sol Republic Deck Speaker Replacement: step 6, image 1 of 1
      • Remove 4 3.63 mm Phillips #0 screws holding the bracket.
      Ask FixBot
    7. Sol Republic Deck Speaker Replacement: step 7, image 1 of 1
      • Use the hairdryer to soften the glue holding the speaker to the plastic plate.
      Ask FixBot
    8. Sol Republic Deck Speaker Replacement: step 8, image 1 of 1
      • Gently pull up on the speaker.
      Ask FixBot
3 other people completed this guide.
Jonathan Holtman
410 Reputation
2 Guides authored
IUPUI, Team S3-G1, Baechle Spring 2017 Member of IUPUI, Team S3-G1, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G1
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 84
All Time: 2,755
