Soft Touch Plastic Coating Removal
    1. Soft Touch Plastic Coating Removal, Clean With Isopropanol: step 1, image 1 of 3 Soft Touch Plastic Coating Removal, Clean With Isopropanol: step 1, image 2 of 3 Soft Touch Plastic Coating Removal, Clean With Isopropanol: step 1, image 3 of 3
      • Generously apply alcohol directly to the goo.
      • Let it dissolve for a few seconds.
      • Scrub until clean.
      Ask FixBot
Coat or vinyl wrap the shiny plastic to your liking. Some ideas include rubberized paint (plastidip) or flocking.
8 other people completed this guide.
Metals
313 Reputation
1 Guide authored
2 Guide Comments
Isopropanol is commonly called isopropyl alcohol. It's found in pharmacies as "rubbing alcohol". Also sold in most hardware stores. Typically sold in strengths of 70% or 91%. The rest is water.
Isopropyl alcohol evaporates fairly quickly. The higher percentage of alcohol the faster the mixture will evaporate.
To deal with the evaporation, either work on a small area at a time, or wet the sticky part and wrap it in plastic wrap to allow the isopropyl alcohol to work for a time. Use a bit of paper towel to hold the alcohol where you want it.
You may want something to scrape off the goo rather than just trying to rub it off. iFixit has a soft plastic "iFixit Opening Tool" which will work, and may be safer for the underlying plastic than, say, a plastic paint scraper. The link has others options too, like the Spudger and Opening Picks.
Prying and Opening Tools
Get some "Goop" or other hand cleaner too. (Goop might also help remove the sticky paint. Haven't yet tried that.)
Winston - Reply Share
Ich habe die Erfahrung gemacht, dass Dimethylsulfoxid DMSO eine viel bessere Wirkung hat. Dieses Lösungsmittel wird oft auch als Heiltropfen verkauft. Es ist ratsam diese Substanz mit Handschuhen aufzutragen da es im wahrsten Sinn durch die Haut geht.
https://de.wikipedia.org/wiki/Dimethylsu....
Brudix - Reply Share
Past 24 Hours: 20
Past 7 Days: 148
Past 30 Days: 818
All Time: 28,349
