SodaStream Source Internal Rubber Seal Replacement
    1. SodaStream Source Internal Rubber Seal Replacement, SodaStream Source External Disassembly: step 1, image 1 of 3 SodaStream Source Internal Rubber Seal Replacement, SodaStream Source External Disassembly: step 1, image 2 of 3 SodaStream Source Internal Rubber Seal Replacement, SodaStream Source External Disassembly: step 1, image 3 of 3
      • Remove the soda bottle and the CO₂ canister from the machine.
      Ask FixBot
    2. SodaStream Source Internal Rubber Seal Replacement: step 2, image 1 of 2 SodaStream Source Internal Rubber Seal Replacement: step 2, image 2 of 2
      Tool used on this step:
      Phillips #1 Screwdriver
      $8.99
      Buy
      Ask FixBot
    3. SodaStream Source Internal Rubber Seal Replacement: step 3, image 1 of 2 SodaStream Source Internal Rubber Seal Replacement: step 3, image 2 of 2
      • Pull the outer cover away from the front of the device.
      Ask FixBot
    4. SodaStream Source Internal Rubber Seal Replacement: step 4, image 1 of 1
      $8.99
      Buy
      Ask FixBot
    5. SodaStream Source Internal Rubber Seal Replacement: step 5, image 1 of 2 SodaStream Source Internal Rubber Seal Replacement: step 5, image 2 of 2
      Jimmy
      $7.95
      Buy
      • Firmly pull the front cover off.
      • This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
      Ask FixBot
    1. SodaStream Source Internal Rubber Seal Replacement, SodaStream Source  Internal Disassembly: step 6, image 1 of 3 SodaStream Source Internal Rubber Seal Replacement, SodaStream Source  Internal Disassembly: step 6, image 2 of 3 SodaStream Source Internal Rubber Seal Replacement, SodaStream Source  Internal Disassembly: step 6, image 3 of 3
      • Push the brass bar, located in the top of the device, out of the carbonating block.
      • You can use the end of your screwdriver to push this piece out.
      Ask FixBot
    2. SodaStream Source Internal Rubber Seal Replacement: step 7, image 1 of 3 SodaStream Source Internal Rubber Seal Replacement: step 7, image 2 of 3 SodaStream Source Internal Rubber Seal Replacement: step 7, image 3 of 3
      • Slide the yellow battery cover up and away to remove it from the device.
      Ask FixBot
    3. SodaStream Source Internal Rubber Seal Replacement: step 8, image 1 of 2 SodaStream Source Internal Rubber Seal Replacement: step 8, image 2 of 2
      • Unhook the bottom piece of the plastic arm on each side of the device.
      Ask FixBot
    4. SodaStream Source Internal Rubber Seal Replacement: step 9, image 1 of 2 SodaStream Source Internal Rubber Seal Replacement: step 9, image 2 of 2
      • Lift the top of the plastic arm with the spudger and remove it on both sides.
      Ask FixBot
    5. SodaStream Source Internal Rubber Seal Replacement: step 10, image 1 of 2 SodaStream Source Internal Rubber Seal Replacement: step 10, image 2 of 2
      • Remove the plastic piece, located near the front of the carbonating block, from both sides of the device using a plastic opening tool or nylon spudger.
      Ask FixBot
    6. SodaStream Source Internal Rubber Seal Replacement: step 11, image 1 of 2 SodaStream Source Internal Rubber Seal Replacement: step 11, image 2 of 2
      • Remove the plastic oval and the spring within it.
      Ask FixBot
    7. SodaStream Source Internal Rubber Seal Replacement: step 12, image 1 of 2 SodaStream Source Internal Rubber Seal Replacement: step 12, image 2 of 2
      • Pull the loader tab cover down and away from the rest of the carbonating block.
      Ask FixBot
    8. SodaStream Source Internal Rubber Seal Replacement: step 13, image 1 of 1
      • Remove the three 17.9 mm screws located on the right side.
      • These screws may be difficult to access.
      Ask FixBot
    9. SodaStream Source Internal Rubber Seal Replacement: step 14, image 1 of 2 SodaStream Source Internal Rubber Seal Replacement: step 14, image 2 of 2
      • Unhook the four clips on the top of the carbonating block and remove the plastic cover.
      Ask FixBot
    10. SodaStream Source Internal Rubber Seal Replacement: step 15, image 1 of 3 SodaStream Source Internal Rubber Seal Replacement: step 15, image 2 of 3 SodaStream Source Internal Rubber Seal Replacement: step 15, image 3 of 3
      • Lift the clips located on both sides with the plastic spudger. Slide the front cover off.
      Ask FixBot
    11. SodaStream Source Internal Rubber Seal Replacement: step 16, image 1 of 2 SodaStream Source Internal Rubber Seal Replacement: step 16, image 2 of 2
      • Unhook the silver spring arms on both sides of the device by pushing down.
      Ask FixBot
    12. SodaStream Source Internal Rubber Seal Replacement: step 17, image 1 of 1
      • Grip the right and left sides of the device and pull it into two identical halves.
      • Once these two pieces are apart, all remaining internal components will fall out of the device.
      Ask FixBot
    13. SodaStream Source Internal Rubber Seal Replacement: step 18, image 1 of 3 SodaStream Source Internal Rubber Seal Replacement: step 18, image 2 of 3 SodaStream Source Internal Rubber Seal Replacement: step 18, image 3 of 3
      • Pull the foam pad up and remove it from the front side of the carbonation component.
      Ask FixBot
    14. SodaStream Source Internal Rubber Seal Replacement: step 19, image 1 of 1
      • Remove the six 17.7 mm screws from the underside of the loader tab piece.
      Ask FixBot
    15. SodaStream Source Internal Rubber Seal Replacement: step 20, image 1 of 3 SodaStream Source Internal Rubber Seal Replacement: step 20, image 2 of 3 SodaStream Source Internal Rubber Seal Replacement: step 20, image 3 of 3
      • Pull the loader tab out of the nozzle.
      Ask FixBot
    1. SodaStream Source Internal Rubber Seal Replacement, Internal Rubber Seal: step 21, image 1 of 2 SodaStream Source Internal Rubber Seal Replacement, Internal Rubber Seal: step 21, image 2 of 2
      • Remove the rubber seal from the nozzle piece and replace with the new seal.
      Ask FixBot
35 other people completed this guide.
Alexandra I Curtis
1,151 Reputation
2 Guides authored
USF Tampa, Team S1-G4, Leahy Spring 2017 Member of USF Tampa, Team S1-G4, Leahy Spring 2017
USFT-LEAHY-S17S1G4
3 Members
84 Guides authored
57 Guide Comments
Where can I purchase the internal rubber seal? Thanks Ronzo (Australia)
Ron Hayes - Reply Share
I’ll ask the same question as the gentleman above. Where can I purchase the rubber gasket seal? I cannot find it anywhere online. I would also like to purchase the gas delivery tube and is installed.
Thank you
Peter (USA)
Peter De Luca - Reply Share
Our sodastream does not work anymore. It’s the electrick model with three different gasfillings. When you put the waterbottle into the filling station and then you turn your suitably filled bottle down and you try to push some of those lights (- /--/ ---) for to fill your bottle, it sounds like little choked “puff” and then all lights are blinking (I think they tell mailfunction). No gas comes. I have changed new and stuffed gasbottle, power cable is its place and works. So what’s wrong? Thank You allready, Juha Heikkilä (Finland).
Juha Heikkilä - Reply Share
I can’t remove the outer cover, step 3.
Claude Vadeboncoeur - Reply Share
I am also looking for a gasket. Do you have any advice?
Zuzana Karlíková - Reply Share
Past 24 Hours: 89
Past 7 Days: 530
Past 30 Days: 3,488
All Time: 282,662
