SodaStream Source Internal Carbonation Air Hose Replacement
    1. SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source External Disassembly: step 1, image 1 of 3 SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source External Disassembly: step 1, image 2 of 3 SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source External Disassembly: step 1, image 3 of 3
      • Remove the soda bottle and the CO₂ canister from the machine.
      Ask FixBot
    2. SodaStream Source Internal Carbonation Air Hose  Replacement: step 2, image 1 of 2 SodaStream Source Internal Carbonation Air Hose  Replacement: step 2, image 2 of 2
      Tool used on this step:
      Phillips #1 Screwdriver
      $8.99
      Buy
      Ask FixBot
    3. SodaStream Source Internal Carbonation Air Hose  Replacement: step 3, image 1 of 2 SodaStream Source Internal Carbonation Air Hose  Replacement: step 3, image 2 of 2
      • Pull the outer cover away from the front of the device.
      Ask FixBot
    4. SodaStream Source Internal Carbonation Air Hose  Replacement: step 4, image 1 of 1
      $8.99
      Buy
      Ask FixBot
    5. SodaStream Source Internal Carbonation Air Hose  Replacement: step 5, image 1 of 2 SodaStream Source Internal Carbonation Air Hose  Replacement: step 5, image 2 of 2
      Jimmy
      $7.95
      Buy
      • Firmly pull the front cover off.
      • This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
      Ask FixBot
    1. SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source  Internal Disassembly: step 6, image 1 of 3 SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source  Internal Disassembly: step 6, image 2 of 3 SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source  Internal Disassembly: step 6, image 3 of 3
      • Push the brass bar, located in the top of the device, out of the carbonating block.
      • You can use the end of your screwdriver to push this piece out.
      Ask FixBot
    2. SodaStream Source Internal Carbonation Air Hose  Replacement: step 7, image 1 of 3 SodaStream Source Internal Carbonation Air Hose  Replacement: step 7, image 2 of 3 SodaStream Source Internal Carbonation Air Hose  Replacement: step 7, image 3 of 3
      • Slide the yellow battery cover up and away to remove it from the device.
      Ask FixBot
    3. SodaStream Source Internal Carbonation Air Hose  Replacement: step 8, image 1 of 2 SodaStream Source Internal Carbonation Air Hose  Replacement: step 8, image 2 of 2
      • Unhook the bottom piece of the plastic arm on each side of the device.
      Ask FixBot
    4. SodaStream Source Internal Carbonation Air Hose  Replacement: step 9, image 1 of 2 SodaStream Source Internal Carbonation Air Hose  Replacement: step 9, image 2 of 2
      • Lift the top of the plastic arm with the spudger and remove it on both sides.
      Ask FixBot
    5. SodaStream Source Internal Carbonation Air Hose  Replacement: step 10, image 1 of 2 SodaStream Source Internal Carbonation Air Hose  Replacement: step 10, image 2 of 2
      • Remove the plastic piece, located near the front of the carbonating block, from both sides of the device using a plastic opening tool or nylon spudger.
      Ask FixBot
    6. SodaStream Source Internal Carbonation Air Hose  Replacement: step 11, image 1 of 2 SodaStream Source Internal Carbonation Air Hose  Replacement: step 11, image 2 of 2
      • Remove the plastic oval and the spring within it.
      Ask FixBot
    7. SodaStream Source Internal Carbonation Air Hose  Replacement: step 12, image 1 of 2 SodaStream Source Internal Carbonation Air Hose  Replacement: step 12, image 2 of 2
      • Pull the loader tab cover down and away from the rest of the carbonating block.
      Ask FixBot
    8. SodaStream Source Internal Carbonation Air Hose  Replacement: step 13, image 1 of 1
      • Remove the three 17.9 mm screws located on the right side.
      • These screws may be difficult to access.
      Ask FixBot
    9. SodaStream Source Internal Carbonation Air Hose  Replacement: step 14, image 1 of 2 SodaStream Source Internal Carbonation Air Hose  Replacement: step 14, image 2 of 2
      • Unhook the four clips on the top of the carbonating block and remove the plastic cover.
      Ask FixBot
    10. SodaStream Source Internal Carbonation Air Hose  Replacement: step 15, image 1 of 3 SodaStream Source Internal Carbonation Air Hose  Replacement: step 15, image 2 of 3 SodaStream Source Internal Carbonation Air Hose  Replacement: step 15, image 3 of 3
      • Lift the clips located on both sides with the plastic spudger. Slide the front cover off.
      Ask FixBot
    11. SodaStream Source Internal Carbonation Air Hose  Replacement: step 16, image 1 of 2 SodaStream Source Internal Carbonation Air Hose  Replacement: step 16, image 2 of 2
      • Unhook the silver spring arms on both sides of the device by pushing down.
      Ask FixBot
    12. SodaStream Source Internal Carbonation Air Hose  Replacement: step 17, image 1 of 1
      • Grip the right and left sides of the device and pull it into two identical halves.
      • Once these two pieces are apart, all remaining internal components will fall out of the device.
      Ask FixBot
    13. SodaStream Source Internal Carbonation Air Hose  Replacement: step 18, image 1 of 3 SodaStream Source Internal Carbonation Air Hose  Replacement: step 18, image 2 of 3 SodaStream Source Internal Carbonation Air Hose  Replacement: step 18, image 3 of 3
      • Pull the foam pad up and remove it from the front side of the carbonation component.
      Ask FixBot
    14. SodaStream Source Internal Carbonation Air Hose  Replacement: step 19, image 1 of 1
      • Remove the six 17.7 mm screws from the underside of the loader tab piece.
      Ask FixBot
    15. SodaStream Source Internal Carbonation Air Hose  Replacement: step 20, image 1 of 3 SodaStream Source Internal Carbonation Air Hose  Replacement: step 20, image 2 of 3 SodaStream Source Internal Carbonation Air Hose  Replacement: step 20, image 3 of 3
      • Pull the loader tab out of the nozzle.
      Ask FixBot
    1. SodaStream Source Internal Carbonation Air Hose  Replacement, Internal Carbonation Air Hose: step 21, image 1 of 2 SodaStream Source Internal Carbonation Air Hose  Replacement, Internal Carbonation Air Hose: step 21, image 2 of 2
      • Use pliers to unscrew the gold cap piece from both ends of the tube
      Ask FixBot
    2. SodaStream Source Internal Carbonation Air Hose  Replacement: step 22, image 1 of 3 SodaStream Source Internal Carbonation Air Hose  Replacement: step 22, image 2 of 3 SodaStream Source Internal Carbonation Air Hose  Replacement: step 22, image 3 of 3
      • Detach the hose from both sides of the carbonation system.
      • You will have to use force to detach this piece.
      Ask FixBot
26 other people completed this guide.
Hailey Smith
1,591 Reputation
2 Guides authored
USF Tampa, Team S1-G4, Leahy Spring 2017 Member of USF Tampa, Team S1-G4, Leahy Spring 2017
USFT-LEAHY-S17S1G4
3 Members
84 Guides authored
71 Guide Comments
Thanks for the guide, but i currently have this issue where the hose needs to be replaced, but no way of sourcing a spare part? Any clues anyone?
Nathan Roberts - Reply Share
Did you ever find the part for your machine?
nagjoinslipknot - Reply Share
Where would you get this part
magnolia_ca - Reply Share
Exactly the same problem on my Source, but I can't find spare parts anywhere.
Has anyone found where to get them from in Australia?
did you ever find a supplier for the air hose replacement?
mark.jc.wright - Reply Share
Past 24 Hours: 41
Past 7 Days: 231
Past 30 Days: 1,007
All Time: 84,600
