Up to 20% off select tools
SodaStream Source Battery Replacement
Views: 120K
View statistics:
Past 24 Hours:
45
Past 7 Days:
218
Past 30 Days:
880
All Time:
120,199
Comments: 54
32 comments on steps, 22 guide comments.
Go to guide comments
Completed: 30
30 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The SodaStream Source is operated by a 3V lithium battery. If you are experiencing trouble with your device not turning on, or your LED lights are not coming on it could be that your battery needs to be replaced. This guide will instruct you on how to remove the carbonation block and replace the internal battery.
    1. SodaStream Source Battery Replacement, SodaStream Source External Disassembly: step 1, image 1 of 3 SodaStream Source Battery Replacement, SodaStream Source External Disassembly: step 1, image 2 of 3 SodaStream Source Battery Replacement, SodaStream Source External Disassembly: step 1, image 3 of 3
      • Remove the soda bottle and the COâ‚‚ canister from the machine.
      Ask FixBot
    2. SodaStream Source Battery Replacement: step 2, image 1 of 2 SodaStream Source Battery Replacement: step 2, image 2 of 2
      Tool used on this step:
      Phillips #1 Screwdriver
      $8.99
      Buy
      Ask FixBot
    3. SodaStream Source Battery Replacement: step 3, image 1 of 2 SodaStream Source Battery Replacement: step 3, image 2 of 2
      • Pull the outer cover away from the front of the device.
      Ask FixBot
    4. SodaStream Source Battery Replacement: step 4, image 1 of 1
      $8.99
      Buy
      Ask FixBot
    5. SodaStream Source Battery Replacement: step 5, image 1 of 2 SodaStream Source Battery Replacement: step 5, image 2 of 2
      Jimmy
      $7.95
      Buy
      • Firmly pull the front cover off.
      • This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
      Ask FixBot
    1. SodaStream Source Battery Replacement, Battery: step 6, image 1 of 2 SodaStream Source Battery Replacement, Battery: step 6, image 2 of 2
      • Remove the old battery and replace it with a new 3V lithium battery.
      Ask FixBot
30 other people completed this guide.
Author
with
Alexandra I Curtis
1,157 Reputation
2 Guides authored
USF Tampa, Team S1-G4, Leahy Spring 2017 Member of USF Tampa, Team S1-G4, Leahy Spring 2017
USFT-LEAHY-S17S1G4
3 Members
84 Guides authored
22 Guide Comments
Heel de achterkant hoeft er hiervoor niet af hoor juist de voorkant 2 vijsjes en je kan het voorste deksel er af klikken ;)
tomclaes1989 - Reply Share
Perfectly explained! I was afraid to pull the front cover because it does indeed take a lot of force to pull off!!
its important to note it’s a C123A 3v battery, not the C2 3v as I found out after opening
Kevin Shiner - Reply Share
Where is the best place to find these batteries? Canadian tire?
Dancingdaisy007 S - Reply Share
Its the same battery many many products use usually built in , motherboards used it for years.
Kal Jak - Reply Share
Staples has the 123A 3v battery
scottvelasco - Reply Share
Past 24 Hours: 45
Past 7 Days: 218
Past 30 Days: 880
All Time: 120,199
