Up to 20% off select tools
Snowboard Traction Pad Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
6
Past 7 Days:
18
Past 30 Days:
104
All Time:
4,324
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Traction pads are used to give you extra grip when you have one foot out of the bindings. This guide is about detaching and attaching traction pads.
    1. Snowboard Traction Pad Replacement, Traction Pad: step 1, image 1 of 2 Snowboard Traction Pad Replacement, Traction Pad: step 1, image 2 of 2
      • Use a plastic or metal scraper to remove the existing traction pad.
      Ask FixBot
    2. Snowboard Traction Pad Replacement: step 2, image 1 of 3 Snowboard Traction Pad Replacement: step 2, image 2 of 3 Snowboard Traction Pad Replacement: step 2, image 3 of 3
      • If there is any residual adhesive left from the old traction pad, soak it with adhesive remover.
      • Let the adhesive remover sit for a few minutes.
      • Wipe away the residue using a towel and water.
      • Dry the the surface where the new traction pad will be placed.
      Ask FixBot
    3. Snowboard Traction Pad Replacement: step 3, image 1 of 3 Snowboard Traction Pad Replacement: step 3, image 2 of 3 Snowboard Traction Pad Replacement: step 3, image 3 of 3
      • Peel the back off of the new traction pad to reveal the adhesive.
      • When placed, the traction pad should be about an inch away from the rear binding.
      • To avoid creating air bubbles, start with one corner of the pad and roll the rest down.
      • Press down firmly to help it stick to the board and remove any air bubbles that may have occurred.
      • Give the adhesive a minimum of 12 hours to dry before use.
      Ask FixBot
Finish Line
Author
with
Jacob Garcia
101 Reputation
1 Guide authored
Cal Poly, Team 17-4, Forte Winter 2014 Member of Cal Poly, Team 17-4, Forte Winter 2014
CPSU-FORTE-W14S17G4
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 18
Past 30 Days: 104
All Time: 4,324
