Up to 20% off select tools
Snowboard Binding Strap Replacement
Views: 52K
View statistics:
Past 24 Hours:
21
Past 7 Days:
79
Past 30 Days:
333
All Time:
52,148
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
The purpose of this guide is to show you how to remove/replace all of the straps on your bindings. However, you do not need to remove the toe straps to replace the ankle straps and vice versa. Begin this repair guide at the appropriate step relevant to your problem.
    1. Snowboard Binding Strap Replacement, Binding: step 1, image 1 of 3 Snowboard Binding Strap Replacement, Binding: step 1, image 2 of 3 Snowboard Binding Strap Replacement, Binding: step 1, image 3 of 3
      • Release the binding straps by lifting up on the buckle and pulling towards the direction of the end of the ladder.
      • Not all binding straps will release the same way. If you are having trouble releasing your binding straps, please refer to your owner's manual.
      Ask FixBot
    2. Snowboard Binding Strap Replacement: step 2, image 1 of 2 Snowboard Binding Strap Replacement: step 2, image 2 of 2
      • Move the straps and the highback plate out of the way in order to have clear access to the foot pad screw.
      • The highback plate is the vertical support plate located on the heel side of the binding.
      Ask FixBot
    3. Snowboard Binding Strap Replacement: step 3, image 1 of 2 Snowboard Binding Strap Replacement: step 3, image 2 of 2
      • Use a #2 Phillips screwdriver to remove the panhead, 10mm wide, M4 x 12mm screw located in the middle of the foot pad.
      Ask FixBot
    4. Snowboard Binding Strap Replacement: step 4, image 1 of 3 Snowboard Binding Strap Replacement: step 4, image 2 of 3 Snowboard Binding Strap Replacement: step 4, image 3 of 3
      • Use a #2 Phillips screwdriver to remove the four ovalhead M6 x 12mm screws that attach the base plate of the binding to the board.
      • Lift or slide the binding off the board and set the screws aside.
      Ask FixBot
    1. Snowboard Binding Strap Replacement, Binding Strap: step 5, image 1 of 3 Snowboard Binding Strap Replacement, Binding Strap: step 5, image 2 of 3 Snowboard Binding Strap Replacement, Binding Strap: step 5, image 3 of 3
      • Use a 5.5mm flathead screwdriver to anchor the backing bracket located on the inside of the binding.
      • Using a Phillips #2 screwdriver, unscrew the countersunk ovalhead M4 x 16mm screw connecting the heel strap ladder to the binding.
      Ask FixBot
    2. Snowboard Binding Strap Replacement: step 6, image 1 of 2 Snowboard Binding Strap Replacement: step 6, image 2 of 2
      • Unscrew the 10mm long thumb screw connecting the heel strap with its binding connector.
      • Pull the heel strap apart from its binding connector.
      Ask FixBot
    3. Snowboard Binding Strap Replacement: step 7, image 1 of 3 Snowboard Binding Strap Replacement: step 7, image 2 of 3 Snowboard Binding Strap Replacement: step 7, image 3 of 3
      • Using a Phillips #2 screwdriver, locate and unscrew the countersunk ovalhead M4 x 16mm screw holding the heel strap connector to the binding.
      Ask FixBot
    4. Snowboard Binding Strap Replacement: step 8, image 1 of 2 Snowboard Binding Strap Replacement: step 8, image 2 of 2
      • Flip the binding so that the bottom is accessible.
      • Using your hands, pry off the plastic bottom covering starting at the toe end.
      • The bottom may still remain attached on the heel edge. There is no need to completely remove it.
      Ask FixBot
    5. Snowboard Binding Strap Replacement: step 9, image 1 of 3 Snowboard Binding Strap Replacement: step 9, image 2 of 3 Snowboard Binding Strap Replacement: step 9, image 3 of 3
      • Remove the corner foam coverings by grabbing one edge and lifting up.
      • Slide out the toe strap ladder.
      Ask FixBot
    6. Snowboard Binding Strap Replacement: step 10, image 1 of 3 Snowboard Binding Strap Replacement: step 10, image 2 of 3 Snowboard Binding Strap Replacement: step 10, image 3 of 3
      • Using a Phillips #2 screwdriver, unscrew the button head M4 x 10mm screw holding the toe strap with its connector.
      • Slide the toe strap off of the toe strap connector.
      Ask FixBot
    7. Snowboard Binding Strap Replacement: step 11, image 1 of 2 Snowboard Binding Strap Replacement: step 11, image 2 of 2
      • Turn the binding on its side and slide out the toe strap connector.
      Ask FixBot
Author
with
Robert Torres
214 Reputation
2 Guides authored
Cal Poly, Team 17-4, Forte Winter 2014 Member of Cal Poly, Team 17-4, Forte Winter 2014
CPSU-FORTE-W14S17G4
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 21
Past 7 Days: 79
Past 30 Days: 333
All Time: 52,148
