Up to 20% off select tools
Snowboard Binding Replacement
Views: 17K
View statistics:
Past 24 Hours:
7
Past 7 Days:
51
Past 30 Days:
180
All Time:
17,354
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Snowboard bindings are easy to take apart and replace. In this guide we will show you how to replace a Union Force binding. Most snowboard bindings are very similar to remove, but there may be some slight differences.
    1. Snowboard Binding Replacement, Binding: step 1, image 1 of 3 Snowboard Binding Replacement, Binding: step 1, image 2 of 3 Snowboard Binding Replacement, Binding: step 1, image 3 of 3
      • Release the binding straps by lifting up on the buckle and pulling towards the direction of the end of the ladder.
      • Not all binding straps will release the same way. If you are having trouble releasing your binding straps, please refer to your owner's manual.
      Ask FixBot
    2. Snowboard Binding Replacement: step 2, image 1 of 2 Snowboard Binding Replacement: step 2, image 2 of 2
      • Move the straps and the highback plate out of the way in order to have clear access to the foot pad screw.
      • The highback plate is the vertical support plate located on the heel side of the binding.
      Ask FixBot
    3. Snowboard Binding Replacement: step 3, image 1 of 2 Snowboard Binding Replacement: step 3, image 2 of 2
      • Use a #2 Phillips screwdriver to remove the panhead, 10mm wide, M4 x 12mm screw located in the middle of the foot pad.
      Ask FixBot
    4. Snowboard Binding Replacement: step 4, image 1 of 3 Snowboard Binding Replacement: step 4, image 2 of 3 Snowboard Binding Replacement: step 4, image 3 of 3
      • Use a #2 Phillips screwdriver to remove the four ovalhead M6 x 12mm screws that attach the base plate of the binding to the board.
      • Lift or slide the binding off the board and set the screws aside.
      Ask FixBot
2 other people completed this guide.
Author
with
Loren Sunding
118 Reputation
1 Guide authored
Cal Poly, Team 17-4, Forte Winter 2014 Member of Cal Poly, Team 17-4, Forte Winter 2014
CPSU-FORTE-W14S17G4
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 51
Past 30 Days: 180
All Time: 17,354
