Up to 20% off select tools
Snowboard Binding Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
83
All Time:
674
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Very easy
Community-Contributed Guide
Parts
Tools
    1. Snowboard Binding Replacement, Binding: step 1, image 1 of 1
      • Start by having the new snowboard binding and screws set aside. Make sure to also have a standard Phillips screwdriver.
      Ask FixBot
    2. Snowboard Binding Replacement: step 2, image 1 of 1
      • First, align the screw and attach the plastic strip.
      Ask FixBot
    3. Snowboard Binding Replacement: step 3, image 1 of 1
      • Then begin to tighten the plastic strip by using the screwdriver with one hand and then holding the nut with the other to tighten the plastic strip.
      Ask FixBot
    4. Snowboard Binding Replacement: step 4, image 1 of 1
      • This is what it should look like so far.
      Ask FixBot
    5. Snowboard Binding Replacement: step 5, image 1 of 1
      • Now we will begin to attach the strap to the opposite side. Like previously, you will need a screwdriver to tighten the strap once you have aligned the screw and attached the nut on the other side.
      Ask FixBot
    6. Snowboard Binding Replacement: step 6, image 1 of 1
      • Make sure to not tighten it too much as the strap needs to be able to move slightly.
      Ask FixBot
    7. Snowboard Binding Replacement: step 7, image 1 of 1
      • Once everything is tightened properly this is what it should look like. Congrats you have successfully repaired a snowboard binding!!!
      Ask FixBot
      • Now it's time to take a picture with your fix!
      Ask FixBot
Author
with
Justin
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 83
All Time: 674
