Snow Blower Shear Bolt Replacement
    1. Snow Blower Shear Bolt Replacement, Locate new shear bolt: step 1, image 1 of 1
      • The new shear bolt is stored on the top of the auger discharge
      Ask FixBot
    2. Snow Blower Shear Bolt Replacement, Remove the old shear bolt: step 2, image 1 of 3 Snow Blower Shear Bolt Replacement, Remove the old shear bolt: step 2, image 2 of 3 Snow Blower Shear Bolt Replacement, Remove the old shear bolt: step 2, image 3 of 3
      • The shear bolt attaches the auger to the shaft
      • The shear bolt is designed to break preventing damage to the auger and shaft if an hard object is pulled in
      • Locate the side with the missing shear bolt
      • The left side is missing
      • This auger will spin freely on this side
      • Rotate the auger to find where the bolt is on the shaft
      Ask FixBot
    3. Snow Blower Shear Bolt Replacement: step 3, image 1 of 2 Snow Blower Shear Bolt Replacement: step 3, image 2 of 2
      • Use the new shear bolt to push the old broken bolt out of the shaft
      • It should fall out and look like this
      Ask FixBot
    4. Snow Blower Shear Bolt Replacement: step 4, image 1 of 2 Snow Blower Shear Bolt Replacement: step 4, image 2 of 2
      • With the new bolt in place from pushing the old bolt out add a nut
      • Hand tighten
      Ask FixBot
    5. Snow Blower Shear Bolt Replacement: step 5, image 1 of 2 Snow Blower Shear Bolt Replacement: step 5, image 2 of 2
      • Using two 7/16" wrenches tighten the nut on the bolt
      • Do not over tighten
      • Congratulations, both shear bolts have been replaced
      Ask FixBot
2 other people completed this guide.
Jacob Rattray
263 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 28
All Time: 2,853
