Up to 20% off select tools
Snapfon ez One SIM Card Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
7
Past 7 Days:
22
Past 30 Days:
91
All Time:
1,870
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 5 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
The SIM card is a removable storage component inside of the phone. The card stores phone numbers and other important information to the user.
    1. Snapfon ez One SIM Card Replacement, Remove the battery cover: step 1, image 1 of 1
      • Turn off the phone to prevent data loss.
      • Press and slide the battery out to remove it.
      • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
      Ask FixBot
    2. Snapfon ez One SIM Card Replacement, Remove the battery: step 2, image 1 of 1
      • Pry the battery out with your thumb or the iFixit opening tool.
      • Make sure to properly dispose of the old battery at a recycling center.
      Ask FixBot
    1. Snapfon ez One SIM Card Replacement, SIM Card: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Use the tweezers,if needed, to grasp the SIM card for removal. Apply a slight pulling tension and remove it from under the tabs as shown.
      Ask FixBot
To reinsert the SIM card or a new SIM card, position the card in the same orientation seen in the figure with the brass connections facing the phone while using thumb to apply a slight force until the card rest inside of the recessed holder. Make sure the brass contacts of the card and phone connect. Then follow the steps in reverse order to reassemble phone.
Author
with
John Bender
818 Reputation
8 Guides authored
Clemson, Team 6-5, Benson Spring 2014 Member of Clemson, Team 6-5, Benson Spring 2014
CLEM-BENSON-S14S6G5
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 22
Past 30 Days: 91
All Time: 1,870
